Vertex 5500 help
highcap132
Pine Bluff
Hello all,
Having a real problem programming 5500. I have the right cable right software but first time I try to use it radio now givving me error 2 message. I tried to read the radio again always getting timeout issue. Any ideas ? thanks in advance
druhe
Southwest Pa
Hello all,
Did you tell the software what band the radio is operating in ? Another thing did you set the correct com port ?
cmpsa
On the VX-4000/5500/6000, you have to put the mobile into "Programming mode" before you select "Read Radio" from the software.
Shut the mobile off (push & hold power). Press in & hold in the very far left programmable function button (PF1). Press power, so the radio turns on (while still holding the PF1 key).
Once it turns on, you can release your finger off PF1 and the LCD display should read "Clone" or (similiar). My VX-6000 mobiles are outside in vehicles, so I don't have one in front of me.
Then select "read radio" in the software and you should be all set from there. and same goes for programming it, it needs to stay (or be) in "Clone"/programming mode.
Hope this solves your issue.
DaveTan
Milford, MA
Also, I believe there may be two ports for the cable.... (or is that just the 6000?) If so, try the other mic port and see if that works and of course as said before, make sure the radio is in program mode...dt
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I approved your reply, but the OP hasn't logged-in for almost 18 months so he/she probably won't see this.
