vertex 800
hellman718
hello i wanted to know i have a job where we use the repeather alot. but i'm the only one using the vertex. every one else is using the motorola. on there motorola they can talk to each other without going to the repather. but when someone goes on the repaether every one hears it. on my vertex 800 i want to do the same thing with the vertex but i don't know how can anyone help me out?
davidgcet
it is called the talk around channel. they switch to chan 2 or hit the direct/ta button and they transmit and receive on the receive frequency. normal repeater use would be 460.0000 rx and 465.0000 tx(just example freqs), but on TA they are both 460.0000. your radio either does not have a ta channel/button or you simply do not know which one to go to. how about asking your supervisor?
hellman718
would you still be availbe to to hear everyone on the repeater still. and still being on point to point
davidgcet
yes, because the TA channel is the normal receive. so you can hear the repeater and if you are close enough the folks on teh repeater channel can hear you even though you do not go thru the repeater.
