VHF Stubby?
PAGANC412912
Pittsburgh, PA
Stock it is I'm guessing. I run a RH77CA normally but I will be taking Amtrak to my railfan spots in Pittsburgh. Wanted to record the trip without having a massive antenna but something better than stock.
FFPM571
The Mid South
a stubby is exact opposite ... it is barley a 50 ohm Dummy load . I have seen a 5/8 wave whip that was made for the USFS it was nearly 12" .. Use a standard 6-7" whip and you will get what you need.
SurgePGH
Belle Vernon, PA
ecps92
Taxachusetts
Generally works quite well, picked up similar from RS at closing
Great for on-scene monitoring
View attachment 93377not high gain,, but boy can you hide a radio with this.
Mike_G_D
Vista, CA
Had both of these at one time - the ScannerMaster stubby and the Radio Shack Race antenna. I found that the cheaper and not as glossy looking Radio Shack antenna waaaaaaay out-performed the ScannerMaster stubby. Of course I didn't expect anything much from pretty much close to a dummy load in size but I was surprised how much better the RS stubby worked versus the much more expensive (at the time) Scanner Master stubby.
Eventually, I got really curious and cut off the outer covering of the Scanner Master stubby (since it performed so poorly I never really used it anyway). What I found was just about an 1/8th to 1/4 inch piece of wire, stiff, maybe 20 gauge, can't recall exactly, soldered to the center pin of the male BNC plug with some potting or glue or something around the base (I think - been awhile) and then, well, that's pretty much it! Just the outer vinyl plastic glossy coating.
I never opened up the RS stubby but I assume it has at least a little more metal in it, maybe a short coil or large inductor or tiny loops of wire, I know it had a stiff rigid plastic outer covering not the sorta-flexible vinyl thing on the better looking but comparitively far worse performing Scanner Master stubby. So would be a more difficult operation to break open. Plus, it really worked well for me (for what I wanted knowing full well its obvious limitations) and proved its functionality and effectiveness so I never really wanted to destructively dissassemble it.
But it always did amaze me how much the admittedly "more handsome" ScannerMaster stubby cost yet how poorly performing and electrically constructed it was compared to the much lower cost RS stubby!
It would be easy to reproduce the ScannerMaster stubby yourself but maybe not in an as pretty a package: take a male BNC plug and solder a short 20 gauge stiff wire to the center pin, about a quater inch or so, and then put some caulking or glue around the whole thing and, well, there ya go! Expect performance matching appearance and you're all set!
Then I suppose, if you wanted to you could come up with some cool outer covering for the mess take a picture of it and put it on Ebay, call it the "Baby Unicorn SuperGainer ScannerStub Miracle Antenna" or some such with 20dB of gain (over a point source buried in 50 meters of lead in a cave a mile down or so...) and sell it for a profit! Just sayin...
-Mike
vagrant
ker-muhj-uhn
California
To the OP, a Diamond RH519 may work well enough. It is BNC and one could cut it down to RX better for rail freqs. You'll obviously want an analyzer to do that. It is definitely not high gain.
Anyways, I use those Diamond RHF10 stubby antennas as well, mainly for RX. Flexible and fine for nearby, or strong signals. They are definitely tuned for the VHF and UHF amateur bands. They are not high gain, especially for rail freqs. I often use one on a VX3R which keeps things really tidy. Even at 1.5W and using that Diamond antenna, one may be surprised how far it can work effectively.
I also own several of those tiny 1" stubby antennas. I think a paper clip may work better. Still, they work well enough with my tiny low power fox hunt transmitters...you know for when you don't want a signal to be heard that well.
