vpn
nosoup4u
High Bridge, NJ
I have an Asus rt-n66u and flashed it with asuswrt. OpenVPN is built in and very easy to setup.
Sent from my Nexus 6 using Tapatalk
cellphone
Silent key.
Ahwatukee, AZ (Phoenix)
You only need VPN if you want to listen outside of your home network. Even if you use proscan, you will need VPN or a dedicated computer on you home network to listen from outside your home network.
buddrousa
Monitor , Control , Program. VPN = NETWORKING SKILLS. Simple port forwarding is very simple. I have a pc running with 8 scanners running at the same time on PROSCAN
1. BCD536HP 2. BCD996P2 3. BCD996P2, 4. BCT15X 5. BCT15X 6. BCT15 7. BC785D 8. BCD436HP
All 8 logging UID's TGID's plus Recording Audio Remote Controlled pre scanner or log in with TEAMVIEWER and control the PC all with 1 $50 PROSCAN License
