Vx-P929 mdc1200 decode
SirJ
Intelligence Everywhere!
Los Angeles/Ventura County
I have a few channels I want to be able to see the DATA ID when mdc is received. However I cannot find an option ? Mdc1200 is enabled on my radio. I'd also like to tx mdc1200
Ant9270
The Green Weenie
The “P” series is not capable of decoding MDC-1200 ID. However, it can encode. I do not have the software in front of me right now, but you need to go into signaling and change it from “DTMF” to MDC1200. Then you have to enable it under each channel in the signaling column. This depends on your level of firmware, as well. If it’s very old, it won’t have this capability. Only the non “p” series is capable of decoding/encoding with a VMDE-200
