VX4000 - alignment question
g8tzl2004
I have successfully programmed my VX4000 but I want to realign the band pass filters.
I understand I need to use the SVC software for alignment.
The service manual just mentions the standard programming CT-70 cable for realignment but I have also read about having to use a FIF-8 firmware rom adapter and CT88 (rear DB25 cable) to realign the VX4000.
So can I just realign the band pass filters using a standard programming cable?
If not, is the FIF-8 just a basic RS232 to TTL level converter? The service manual shows TXD, RXD and GND lines which suggests that alignment may be done using a "3 pin" level converter whereas the VX4000 just uses "2 pins" (GND and clone) for basic programming?
Can I use my ancient Yaesu programming box which you can set up for 2 or 3 pin programming?
