VX414 Programming Software
CallumC8
UK
Hi all.
I've an issue with my current software for the VX414s (UHF) that I recently purchased. The software they came with seems to not work. When you click to read from the radio and switch the radio on, nothing happens. I've been told I possibly need a newer version of the software.
I've tried to create an account on the business online link for Vertex Standard where someone on this forum pointed another user in the direction of software but currently (4 weeks later) nobody has got back to me from Vertex nor have they followed up my email asking for assistance.
Can anyone give me some assistance on what would be best to do next?.
Many thanks.
MBill
VX414
Have you tried turning on the radio first and then click on the upload button? I find this is the
sequence for the VX-410 series (414, 417, 420). Works for me.
Vertex seems to have a different approach for their various radios. Some I find you have to
turn on the radio first, others you turn on after software tells you to do so. Wish they would
standardize it.
Hope this helps.
CallumC8
UK
Hi MBill
I've tried what you have suggested. Still not luck. I just have the Download function box on screen and nothing happening. It still says to switch radio off then back on to start downloading but that doesn't do anything.
MBill
In the Software program menu click on the "Config" selection. As I recall you can select the proper
com port the software wants to see so it will run properly. Most often this is Com Port 1. It might
be different on your computer. I assume you are using a serial cable.
There is a newer cable using the USB ports which you need to have the driver for. The latest
version is FIF-12. If you are using the FIF-10 of FIF12 make sure the correct one is selected
from the choices in the config menu. If you are using the FIF10 or 12, make sure you are using
the same USB port which you originally used to set up the software. At least on my computer
it won't work unless I use the same USB port I originally plugged the cable into on installation
of the driver software.
You may, of course, have a problem with the software vs. computer or the programming cable
itself.
Sorry, I can't be of more help.
