VXD-720 Scan List Question
rgchristy
Delco, PA
I read this from the manual:
Your radio can support up to 250 scan lists,with a maximum of 16 members in a list. Each scan list supports a mixture of both analog and digital entries.
My question is: Is it possible to scan multiple scan lists at one time or are you limited to just one?
Thanks,
Rich
chief21
Western NC (Summer); Tampa Bay FL (Winter)
Hi Rich -
I see that you haven't received any responses as yet, so I'll take a shot at it. While I don't own a VXD-720, I am familiar with various software-programmable radios and virtually all of them allow for multiple scan lists, but usually only one list can be active at a time.
Typically, you will have to set up each list in the software and you might also have to dedicate a button or add a menu item to allow you to call up a list or change to a different one. Depending on the software that you're using, very often the in-program HELP feature will explain each field in more detail, so poke around and see if you can find a more precise answer.
Hope this helps...
John
