VXD-7200 Programming Cable
FastusBirdus
Trying to figure out which programming cable I need for our VXD-7200 mobiles.
CT-150? CT-151? CT-154? In our installation, I've got easy access to front or rear to plug in.
Getting conflicting information from different documentation.
WISCOMM
Elm Grove, WI
My docs showing the following are compatible with the VXD-7200:
CT-150 Programming cable rear accessory connector
CT-151 Programming cable rear accessory connector
CT-154 VXD Mobile Front Programming Cable
The CT-154 being the cheapest of the lot.
Craig
FastusBirdus
I think CT-151 is also listed as the cable for the VXD-R70 repeaters. Wonder if it works on the XPR 8400. Probably not.
