VXR-1000 Programming and cable
redmtnex
Hi All. I have two vxr-1000's that I need to program. I have searched and searched for info on building s programing cable with grey results. I have the CE-22 software for windows. Every cable I have attempted to put together fails with a timeout error. Guess what I need is the correct pinout to the microphone plug to a usb ftdi or serial port.
radiotweester
Oregon
This is covered in other threads, but like all Vertex radios - try clicking [read] in the software then powering up the VXR. You might need to mess with your timing of doing this.
The cable should be the standard mic cable (RJ45 data pin 1, ground pin 4).
I've used the CT-42 (stereo plug) and adapted it as needed. The ADMS (for HAM) works well too. Even the old RS scanner programmer will work in a pinch. I THINK data is the center ring of the stereo plug, but I don't have it in front of me and ground is frame ground.
I'd recommend serial not a usb adapter, though usb should work as Com 1.
redmtnex
Thanks for that info. Still no luck though. I have been trying this with a usb device. will switch to a serial cable instead
radiotweester
Oregon
You might try changing the program's compatibility to XP or just use an older computer. Win 10 doesn't seem to like playing nice with a lot of radio programs
redmtnex
Found this on two different web sites, so if 1 is data and 4 is ground then this chart (1 data - 5 ground) is incorrect?
78082
redmtnex
Thanks I will try that. I am still doubting my pinout though. I found one chart on two different web sites that list the microphone pinout as follows. 1-fast, 2-ground, 3-ptt, 4-mic, 5-mic earth, 6-+5V, 7-up, 8-dwn.
radiotweester
Oregon
Disregard my reply #7 w/o pics - I timed out and can't edit it.
I had to consult the SM. I had the vx4200 in mind. I've blue dotted the data and ground.
It would not surprise me if the the SM might be in error. This was the case with the HDB15 on the back of the 4200... It's reversed!
I would try tab down, gold pins up, wire entry towards you, 1st pin on the left data 4th pin from the left as ground. If this doesn't work, try the pin farthest to the right as data and leave the ground line in place.
redmtnex
Thanks. Might be a couple of days before I can work on it. Will post back with my results.
redmtnex
OK still no luck with my usb ftdi dongle. I am wondering if my usb dongle has a problem. The image for the vx1000 is exactly the same as for the vxr-1000 via the vxr-1000 service manual. So I am wondering if I need actually 3 connections and not 2 IE just TX and Ground. This weekend I will attempt to build a serial rs232 cable. That brings up the question as to which pins on the serial I connect. If just two? 3txd to 8 clone, and 5 ground to 5 ground?
78220
ramal121
Lots and lots of watts
Calif Whine Country
Never played with those, but I see pin 7 is CL SW (clone switch?). Maybe that needs to be asserted to put it into clone mode?
redmtnex
No happiness with rs-232. I can see two scenarios being a problem. 1- the software. 2- the OS. You can no longer degrade to Win XP in Win 10, only to Win 7. I do have a Win XP machine and as time permits will try it.
radiotweester
Oregon
You're aware this is NOT a direct RS-232 connection! You need that little interface/converter board that's in the backshell of the DB-9.
