BC125AT: Weather Alert Standby
smislt
Illinois
I have my backlight set to go on Keypress+Squelch. When I go to Weather Alert Standby, the backlight stays on all the time. Since the squelch is not broken in that mode until a tone is received, I don't understand why the backlight stays on.
Celeritas670
Central Michigan
Once the scanner is in the Alert Standby mode, you can toggle the backlight by tapping the power/light key. (Not sure if it makes a difference, but my normal backlight setting is 'Always on' and I use the toggle the same way.)
smislt
Illinois
I turned it off as you said, but it keeps coming back on. Why is that?
Scan125
UK
This is interesting to know for my Scan125 Control Program.
If you have Scan125 then I would be interested to know if the program's Backlight Control Slider gets out of sync when you turn Weather WX Alert On/Off via the program's WX Alert checkbox?
If this is a problem/feature on all BC125AT scanners then I guess I'll need some more details from my user's so I can update the program.
Could get complicated as we have Always Off, Squelch, Keypress, Key+Squelch and Always On to check as they may not all perform the same way with WX Alert?
smislt
Illinois
Scan 125, interesting post. I'll be looking for a reply. Can anyone answer the following? I have a channel in bank one that I have set for priority. When in Weather Alert Standby, does the BC125AT also monitor the priority channel as well as the WX freq?
Scan125
UK
I'll have to pass on this question as I do not have a BC125AT and there is no WX Weather Alert on the UBC125XLT model.
However reading the BC125AT user manual seems to "suggests" it does BUT the wording used is typical scanner wording where determination of fact and clarity is not that easy. Testing would clarify the situation.
