WEST VIRGINIA DEPT HIGHWAY FREQUENCY
columbas
Hello Everyone, I was told that WV Dept. highways will be changing from conventional frequencies to a Trunk System. Does anyone have any information on this subject ? Also if they do will it be encrypted ?
jonwienke
More Info Coming Soon!
VA
Most likely they will use SIRN, already used my most state agencies. Encryption is unlikely.
WV8EJW
Shady Spring,WV
It will be a very long process for them to switch over to SIRN is they will have to install new radios into well over a thousand vehicles as well as install base radios at all the county headquarters and outposts statewide.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
I was wondering also I live in district 4 and never hear anything can someone confirm if it still works?
47.28000WXB726BM71.9 PLWVDOH D4WVDOH District 4FMPublic Works
Remove the PL. Also, make sure you are using a good antenna designed for that band. I know in District 5, they use a UHF repeater from their low-band radios. I see in the DB that District 4 has one as well.
