Westchester County TRS Unit ID's
APX8000
Sarcastic Member
AES-256 secured
Open the Unitrunker program and select the "systems" tab. Double-click on the label for the Westchester system and will open up that system. Click the "users" label on the bottom. Click the floppy disk on top that says "export this system." Save that file to your desktop. It will now appear as a .xml file on your desktop. If you double click it and scroll through you'll see the labels attached to the UID and talkgroups ton have. Upload that here and I'll work through it but it will take a bit to manually convert it to .csv
radioman2001
New York North Carolina and all points in between
A few notes on the log, all confirmed by radio traffic ID's have a star next to the description. All others are assumptions based on known department ID's (first 3 numbers in string) Some are wild guesses and some are posted with times and date they seem to log on each day. There are a LOT of ID's that only log on/off only each day so they are hard to decode. Some are out of normal ID numbers some are cloned ID's that have been stunned. You might want to just convert those that are confirmed since there are several hundred of them.
I had to zip them for RR to upload them.
  • UNITRUNKER FILES 8-24-17.zip
APX8000
Sarcastic Member
AES-256 secured
This will be my project tonight and tomorrow. Had an outpatient procedure done so this should pass the time.
seagravebuff60
Short Bus Reject
Snow Bird
Thank you! Now i might need help importing the IDS into FreeScan but i might be able to figure it out. But ill let you all know if i need help. lol
seagravebuff60
Short Bus Reject
Snow Bird
Any update on this?
I have also found some UIDs:
i32502- C2211 Katonah
i32507 - E115 Katonah
i35000- Somers Base
I have found out that the UIDs are sorta numbered in a organized way. Each Department has its own prefix witch are the first 3 numbers and the last 2 are apparatus in that set department. In the unit ID if the last 2 numbers are 0 then it is the base radio for that department. Usually the chief of the department has an ID of i###02 but I have only found this for a few departments. Now as for Ids that only have 3 numbers in the ID (i###) are most likely the dispatch Console, and I think there is a pattern or sequence in with those IDs are numbered as well, but I have not found one yet.
radioman2001
Refer back to post #13 that is the most accurate description of ID assignment after listening for over 9 years.
Quote" i32502- C2211 Katonah
I don't know what that is, the ID should be for Katonah Chief portable radio. Just 2211 at least in Unitrunker.
The other 2 you listed follow normal numbering.
You may find that sometimes officers and personnel operating on the scene use a radio not assigned to them, probably because that radio is closer to them at the time.
For Dispatch I suspect that the ID is either the operators number or even a job assignment number. Since I have copied several hundred dispatcher ID's, (I don't believe that there more than 25 Dispatcher's), so my guess is a job number of the day assigned by the CAD to a particular dispatcher.
I am now going to start looking at the numbers and see if they increment during the day.
seagravebuff60
Short Bus Reject
Snow Bird
" i32502- C2211 Katonah "
2211 is the chief car. The Katonah chef is 2211. i35502 is the unit identifier.
seagravebuff60
Short Bus Reject
Snow Bird
Not to be a pain but how long do you think this will take?
If you export it from Unitrunker and put the file up here I'll go through and convert it to .csv and combine the others posted as well so it can be uploaded to EZScan and Sentinel (I believe I just have to put an "i" in front of the UID for Uniden).
Is there anyway that you can import a .csv to freescann or proscan so that when this is done i don't have to manually import it into my scanner
APX8000
Sarcastic Member
AES-256 secured
Sorry but dealing with the hurricanes the last few weeks. I know with EZScan you import it as a .csv file.
seagravebuff60
Short Bus Reject
Snow Bird
Oh Ok no worries just hope your ok and safe. Just was curious. As i am not logging any IDs because i was going to import this list. Thanks for doing this again.
bill11312
Brewster, NY
Car 2191 32302
engine 155 32309
rescue 7 36103
45-medic 3 41101
80-b-2 35008
engine 51 32709
ladder 19 32710
car 2071 31101
engine 174 31507
squad 15 31908
rescue 3 31511
engine 176 31509
engine 170 32107
car 2171 32101
ladder 4 31909
battalion 14 50140
engine 175 31508
battalion 14 portable 50141
car 2121 31513
airport 17 50181
tower ladder 15 32108
rescue 16 36014
car 2531 36001
engine 271 36008
fairview hq 31500
car 2443 35006
rescue 3 officer 31504
hartsdale hq 32100
tower ladder 14 33416
rescue 31 33415
engine 137 31409
car 2371 34101
car 2073 31105
car 2321 33602
61-a-4 40412
45-medic 1 41107
engine 158 30306
tanker 17 30311
car 2582 30304
car 2162 32003
engine 13 32008
engine 10 32007
car 2161 32001
65-b-2 40503
car 2284 33407
rescue 12 34910
car 2313 34905
84-b-2 35608
53-b-1 30607
87-a-4 41207
engine 185 35014
80-b-1 35007
car 2072 31103
engine 149 31109
ladder 67 31125
31104
car 2172 32105
car 2172 32102
car 2243 32805
36-medic 1 41603
tower ladder 6 35818
70-b-1 40951
seagravebuff60
Short Bus Reject
Snow Bird
Car 219132302
engine 15532309
rescue 736103
45-medic 341101
80-b-235008 ........
Thanks i will add this to my list and update it.
This is great, this was the whole purpose i set this forum up, where people could come and elaborate. Thanks again.
seagravebuff60
Short Bus Reject
Snow Bird
i31000- Croton Base
i32100- Fairview Base
i50132- Battalion 10
i50179- Airport 7
i50052- Phelps ER
i50051- N Westchester ER
i50048- Hudson Valley ER
i50056 -Westchester Med. ER
i50049- Lawrence ER
i35010- E180 Somers
i35011- E181 Somers
i35012- E183 Somers
i35014- E185 Somers
i35016- E188 Somers
seagravebuff60
Short Bus Reject
Snow Bird
I found out a way to import a excel into pro-scan.. Here is the post if anyone is interested
(Originally Posted by ProScan)
You should be able to without to much difficulty.
Here's how:
1. Using Excel, export to a text format (Comma or Tab delimited) file
2. Open the text file and select all (Ctrl + A)
3. In ProScan, select a group where you want the UIDs imported
4. Click the Get Clipboard button
5. Choose the Delimiter; Comma, Tab, or Custom
6. Click the Get From Clipboard Everything button
7. If any rows are grayed out. It's because not valid TGID or UID. In that case may have to modify the UID's in the text file
8. Once you have valid UIDs, the rows will be checked
9. If the UID's don't have an "i" prepended then prepend an "i" to the UID
10. Click Import
ac316scu
Car 2191 32302
engine 155 32309
rescue 7 36103
45-medic 3 41101
80-b-2 35008
engine 51 32709
ladder 19 32710
car 2071 31101
engine 174 31507
squad 15 31908
rescue 3 31511
engine 176 31509
engine 170 32107
car 2171 32101
ladder 4 31909
battalion 14 50140
engine 175 31508
car 2121 31513
airport 17 50181
rescue 16 36014
car 2531 36001
engine 271 36008
fairview hq 31500
car 2443 35006
hartsdale hq 32100
rescue 31 33415
engine 137 31409
car 2371 34101
car 2073 31105
car 2321 33602
61-a-4 40412
45-medic 1 41107
engine 158 30306
tanker 17 30311
car 2582 30304
car 2162 32003
engine 13 32008
engine 10 32007
car 2161 32001
65-b-2 40503
car 2284 33407
rescue 12 34910
car 2313 34905
84-b-2 35608
53-b-1 30607
87-a-4 41207
engine 185 35014
80-b-1 35007
car 2072 31103
engine 149 31109
ladder 67 31125
31104
car 2172 32105
car 2172 32102
car 2243 32805
36-medic 1 41603
70-b-1 40951
Here it is cleaned up a bit
i41603- 36 Medic 1
i41107- 45 Medic 1
i41101- 45 Medic 3
i30607- 53-B-1 Millwood
i40412- 61-A-4 Harrison
i40503- 65-B-2 KBHVAC
i40951- 70-B-1 Mt Kisco
i35007- 80-B-1 Somers
i35008- 80-B-2 Somers
i35608- 84-B-2 Vista
i41207- 87-A-4
i50181- Airport 7
i50140- Battalion 14
i50141- Battalion 14
i31101- C2071 Croton Falls
i31103- C2072 Croton Falls
i31105- C2073 Croton Falls
i31513- C2121 Fairview
i32001- C2161 Harrison
i32003- C2162 Harrison
i32101- C2171 Hartsdale
i32105- C2172 Hartsdale
i32102- C2172 Hartsdale
i32302- C2191 Hawthorne
i32805- C2243 Mamaroneck
i33407- C2284 Mt Kisco
i34905- C2313 Sleepy Hollow
i33602- C2321 N. White Plains
i34101- C2371 Pleasantville
i35006- C2443 Somers
i36001- C2531 Yorktown
i30304- C2582
i32007- E10 Harisson
i32008- E13 Harrison
i31409- E137 Elmsford
i31109- E149 Croton Falls
i32309- E155 Hawthorne
i30306- E158 Banksville
i32107- E170 Hartsdale
i31507- E174 Fairview
i31508- E175 Fairview
i31509- E176 Fairview
i35014- E185 Somers
i36008- E271 Yorktown
i32709- E51 Mamaroneck
i31500- Fairview HQ
i32100- Hartsdale HQ
i32710- L19 Mamaroneck
i31909- L4 Greenville
i31125- L67 Croton Falls
i34910- R12 Sleepy Hollow
i36014- R16 Yorktown
i31511- R3 Fairview
i31504- R3 Fairview
i33415- R31 Mt Kisco
i36103- R7 Banksville
i31908- Squad 15 Grenville
i30311- T17 Banksville
i33416- TL14 Mt Kisco
i32108- TL15 Hartsdale
i35818- TL6 White Plains
seagravebuff60
Short Bus Reject
Snow Bird
seagravebuff60
Short Bus Reject
Snow Bird
I have linked the wiki page into the the database for the trunked system i will also link this thread too... The ticket Is curently open and i hope to link the pages together...I am very excited for this wiki.. Thanks again
