Westchester County Trunked System
W2MR
I'm programming a BC780XLT scanner with the Westchester County T-Band Trunked System.The RR listing shows two sets of Base/Spacing/Offset data. Should I program both (the scanner will accept three) or assume that the top listings are for the North System and the bottom listings are for the South System?
GTR8000
NY/NJ Database Guy
BEE00
Program them both. The South zone has a 470 MHz frequency assigned to it.
W2MR
Thank you. It's working in the search mode.
Sonic1131
New York
Yesterday I purchased a brand new Uniden Home patrol. The Westchester County Trunking is not working in the scanner.
Do I have to change a setting for it to work ?
W2MR
Sorry, I dont know. Maybe someone else can help. Perhaps the Uniden scanner forum?
GTR8000
NY/NJ Database Guy
BEE00
The system looks correct in Sentinel. Make sure you have the service types enabled.
Menu > Select Service Type
Depending on what you want to listen to, the system uses the following service types, which should be enabled:
Emergency Ops
EMS-Talk
Fire Dispatch
Fire-Talk
Hospital
Multi-Dispatch
Multi-Tac
Multi-Talk
Public Works
Transportation
Then press Accept.
Sonic1131
New York
Thank you both !
Yes that was the issue. I enabled Fire Talk ect. All seems to work.
Your reply is appreciated .
GTR8000
NY/NJ Database Guy
BEE00
Thank you both !
Excellent, glad you're up and running. I believe the HP-1 has only a few of those service tags enabled by default.
GTR8000
NY/NJ Database Guy
BEE00
FYI, after looking at the system the other day, I realized most of the function tags (service tags on the HP-1) were incorrect. I changed them last night, and also reorganized the system slightly. If you're scanning the system in the HP-1 from the main database, you might notice a slight change when you update the HP-1's database on Monday.
The system now uses the following function tags/service types:
Emergency Ops
EMS-Tac
Fire Dispatch
Fire-Tac
Hospital
Public Works
Transportation
No longer used:
EMS-Talk
Fire-Talk
Multi-Dispatch
Multi-Tac
Multi-Talk
