We've come a long, long, long, way from the old days of "recreational radio".
Southern California
When I was a kid, and that's been a while, I was so happy to take my little transistor radio with me. I am talking about the old Japanese 9volt AM radio.
Listen to KSL or KFI between Ventura ca. and Nebraska.
I felt like I was a big time Dxer. Also took my cb walkie talkie. Again the 9volt channel 14 radio.
53 years playing radio.
DW
So. Cal.
mikethedruid
Sneedville, TN
DW
So. Cal.
At night, many of those little Japanese 6 transistor AM BCB radios could really suck in the stations, even from far away. The toughest thig was to tune them because of the size of the knob, usually connected directly to the variable condenser. You had to be able to move it just a tiny bit to tune between the many stations which one could receive. I collect antique radios, and have a few of those old transistor radios. With the one I use most, from my home in northeast Tennessee, I can pick up stations from Chicago, Cincinnati, even New Orleans !
VK3RX
Thaumaturge
Australia
During our COVID "lockdown" period here last year a few of us on an AR forum decided to write about our start in electronics, AR etc.
Below is an extract from mine.
When I was 14 I was given a transistor portable for my birthday,. It did not have a telescopic antenna, so to improve reception I fitted one with a wire loop around the internal ferrite rod. Reception was improved further when I fitted a socket to the radio and connected an external long wire antenna outside. I then spent many hours each night tuning in AM broadcast stations around the country.
Then one night I decided to tune the dial to the highest frequency, and log stations while tuning down. The dial had about 5° of overshoot past the horizontal maximum mark, and I had already established that hard against the stop was around 2300kHz because I’d heard boats in the local sea rescue squadron testing on weekends.
I started tuning down and almost immediately came across someone talking about radio gear, and he did not sound like a broadcast station announcer. He finished talking and someone else came up and the conversation went back and forth.
I’d discovered 160 meters AM, and I never bothered with broadcast band AM stations again.
Southern California
I run up to 160m but now I use my radio shack shortwave.
Just about that soft mellow sound of A.M.
We have property out in Fillmore CA.
Plenty of room for a 160m antenna, my problem here is I need the general ticket.
I am still a tech.
A bit off topic but to say I like monitoring 160.
DW
So. Cal
