forkeye
Okay so this has driven me crazy. Its the only car I have the problem with so here it goes.
I bought 3 K30 Magmount antennas from K40 as part of a promo run by the Pilot travel centers.
I use one on rental cars when I travel. I use the other in my personal vehicle. The third is a spare.
Antenna 1 (the rental car antenna) works like a champ. SWR's are always a steady 1.5:1 no matter what vehicle I am renting. If there's metal on the vehicle, it sets down, run the coax into the passenger compartment. Presto! Great antenna. Was in the Mojave and talking to Kenosha, Wisconson a couple of weeks ago. Great antenna running barefoot on a chintzy Midland 75-822 handhelld unit with the car adapter running in Hi Power (4 watt PEP) mode. Great little portable radio, great for travel; great weather radio. I do a lot of highway driving so this radio with the Anytone PTT mike package is great. Just like having a real CB attached to the dashboard.
Antenna 2 (personal car antenna) has crazy SWR's. Doesn't matter where I put it on the car. Roof, trunk lid, etc. It starts out fine, a couple of bumps in the road, then its a nutty SWR. At one point it was banging 7:1. I am picking up Skip, radio has not blown finals, nothing.
As soon as I open the car door or the trunk lid, SWR's are fine. No explanation. Run the coax through the window, and roll it up a bit, SWR's are crazy again.
So ... enter Antenna 3.
I replace Antenna 2 with my spare (Antenna 3). I'm getting the same whacky SWR's.
I write to K40 Corp. Tell them the above. They write back saying the radio/antenna are not grounded. So I start searching for some kind of solution to this problem. Suggestion is a grounding block to the car's chassis or body. I check my trunk lid, its grounded throughout. Nice old Crown Victoria with metal all over the place. I ground the radio to the inside ground. Same problem. Crazy SWR's. So there's no ground issue there on the inside. Suggestion is turn to a grounding block. Okay, this makes no sense. The coax is 18 feet for a reason. Like the firestick and other no-groundplane antennas, you do 2 quarter waves with a quarter wave on top. The shielded coax is supposed to act as counterpoise to avoid ground. So why use a grounding block? Alas! They don't make a grounding block. So I get a bulkhead mount double SO259 and fashion a ground block using #0 conduit standoff, and voi la, now I have a grounding block for the car body. Run my coax through to the trunk, splice in two PL 259's as suggested.
What happens? I have a super-RF-grounded antenna --- BUT!!!! ... Big But....--- I still have the same problem! Open a car door or pop the trunk, SWR's are fine. Close the door or trunk, boom! SWR's are high.
This whole drifting SWR thing got me rattled. So ... I make an RF air choke to make sure I don't back-end my finals. Nada. No difference. I've wasted more coax.
It works fine with the trunk popped slightly open, but ya know .... not conducive to highway driving and city driving isn't much better. Besides I have stuff in my trunk I don't want taken out of there at a stop light or stop sign.
I have also checked my coax. (A) Hardly any loss. Conductivity is about 99.9999% using my VOM. (B) No shorts. None. Even with the trunk shut no shorts. Zero conductivity between shield and center conductor. Popped open no difference. (C) Checked my patch coax. Its fine. No shorts.
Scratching my head, my nose, my nethers, switching hands and still can't figure this one out.
Been around CB and Amateur Radio since the early 70's, heck I still have my old CB "KWR" license even though they stopped renewing them, oh about 1978 or so.
Short of buying a $250 antenna "tuner" device or an autotuner, any suggestions here?
BTW I just bought a cheapo antenna matcher on Ebay hoping that might just fix the problem and get it over with. I had toyed with a 250pf - 1250 pf variable cap and making a resonance tuner for it, but before I spend the mucho bucks tracking one of those down, maybe someone's got ideas here?
PS -- K40 has no solutions to this issue. They can't explain this. And PPS -- (A) I thought about the Faraday Cage effect but ruled that out because I didn't see RF bouncing around using the FS function on my SWR/Watt/RF Meter. And using RF detector could not find any "leaks". (B) I toyed with the possibility that there is an electrical "short" when the trunk light switch engages or the door light switch engages. But when I manually depress them and check the SWR's, no difference. So its not the electrical system playing tricks on the RF ground.
Thanks much.
Thanks much.
