What am I doing wrong???
mrksbrd
I just bought a uniden bct8, programed NJSP analog trunked frequencies to it, when it is in trunked mode it doesn't pick up any frequencies, when I take it off trunked mode it works fine, but I don't know if I'm rec'ing all the broadcasts(probably not).
Please help, scanner is getting ready to make an abrupt stop against a wall!!!!!
mrksbrd
as far as I know, here is the page i went by
http://www.radioreference.com/modules.php?name=TRSDB&sid=141
entered all frequencies
and entered talk group
34864 883 A1-02 TRP HQ 2-Comm Troop HQ (Buena Vista)
34896 885 A1-03 EAST 3-Comm Dispatch (Buena Vista)
34928 887 A1-04 SOUTH 4-Comm Dispatch (Buena Vista)
34960 889 A1-05 WEST 5-Comm Dispatch (Buena Vista)
34992 88b A1-06 MARINE Marine Police (Atlantic City)
35024 88d A1-07 OPS Car-to-Car
35184 897 A1-12 ACE Atlantic City Expressway
do I have to enter "everything" or just the one's I want
mrksbrd
@ the moment I am in new castle, de just over del memo br. and rec'ing broadcasts but not in trunked mode from them, like I said as soon as I hit the trunk button...it just continually scans
Al42
Long Island, NY, USA
Listen to each of the control channels individually - 857.93750, 858.93750, 859.93750 and 860.93750. You should hear control data on one of them. Do you? If not it has nothing to track.
The talkgroups you want are the first column (you can't enter the ones in the second column, because 'b' and 'd' aren't numbers.)
You only have to enter the talkgroups you want to hear.
DJ88
Brick Twp., New Jersey
Make sure your scanner is set in the trunk mode for a Motorola Type 2 800 system, and that all of the frequencies are programmed. As for the talk groups, program the ones in the "DEC" column only. Do not program the "HEX" talk group ID numbers. That's all you have to program into your scanner. If you manually bring up the control chanels you should hear a buzzing sound. IE: hit the "Hold" or "Manual" button, the channel number and then either "Hold" or "Manual" again and you should hear it. Scanning it in the conventional mode will allow you to hear everything, you just won't see the talk group numbers on the screen.
If you continue to have problems you can call Uniden Customer Service and speak to a technician. They are very cooperative and helpful and will work you through your problem. 1-800-297-1023.
pinoy1042
Sparks, Nv.
i am trying to program a pro-2050 800 trunktracker to work on our new 800 system EDACS. i have read the book over and over cant figure it out, can anyone help with this.....please
jim
DaveH
Ottawa, Ont.
jim
Did you mean the PRO-2052 by chance? The PRO-2050 is not capable of EDACS, but the other is.
Dave
