What is required to change digital modes on the NX-5000 series?
human8472
I am looking to purchase a Kenwood NX-5200 where the digital modes are set to FM/P25/NXDN. I would like to swap the NXDN for DMR, but I am not sure how I would go about doing so or how much it might cost. Do I pay for a different license key and enter it into the radio myself? Is it done via a type of "Depot" software? Thank you.
tweiss3
Is it time for Coffee?
Ohio
You have to buy the DMR entitlement if you do not have it on the radio. It is enabled KPT-300LMC License Management Client (same program to activate KPG-D1N). After it is activated, in D1N top tabs, Model --> Product Information. Read your radio configuration, then turn NXDN off and DMR on, check DMR conventional.
After that, it will delete all your programming, save as a new file and start programming again. Write to the radio and you are done.
tweiss3
Ohio
You will have to check with your dealer, but I think it is in the ballpark of $50, don't quote me though. Compared with the other entitlements, it is inexpensive.
You would need to add:
KWD-5300CV for DMR Tier 2 Conventional and S trunking. Last time I looked LIST price was $60.00
KWD-5301TR is the License key for DMR Tier 3 trunking. List price was $134 as of last year. (This requires KWD-5300CV on top)
KWD-5500EE is the License key for DMR ARC4 Enhanced Encryption. List price was $40.00
As mentioned above, you'd add these to the radio with KPT-300LMC
Then you can program away using KPG-D1N
