What is this?
boernegang
Boerne,Tx
I have seen these on several different trucks in the San Antonio area on I10. Any idea what type of Antenna this is??
How does something like that plug into a common smartphone?
They don't.
The antenna feeds a bi-directional amplifier (BDA) located in the vehicle. The BDA re-radiates the signal inside the cabin.
They can work well if designed well, installed correctly, and used correctly.
If not, they cause interference, don't work, make things worse, etc.
Many years ago I had one in a truck. The BDA portion was built into a cradle that held the phone. The BDA was powered off 12 volts switched by ignition. I mounted an NMO mount on the roof and had a small blade style cellular antenna. Worked really well out in the boonies. Would take a marginal signal and boost it to the point that getting phone calls, text messages and data in/out was possible.
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
Interesting. I guess that's like how those glass mount antennas work in principal?
I read years ago that text messages rode the control channel. So knowing that I always figured if I couldn't make a call I might be able to send a text message. And seen as how a lot of 911 dispatch centers are allowing 911 texts, that could come in handy.
No. The BDA's actually have amplifiers and some filtering that boost the section of the bands that are used for cellular. Done right they can work well.
On the older systems, yeah. Not sure how it works on LTE, I think it's all a data stream and it doesn't matter.
bharvey2
Sweet Jeebus,
Proof the uglier an antenna is, the more people will buy it.
Good grief, you aren't kidding. It looks more like a tiki torch than an antenna! I gotta wonder how much of it is snake oil. It looks more like a top loaded HF antenna especially with that helical winding at the top.
