I'm in Wi and want to start scanning Dane county again. I believe Dane county has moved to P25 Phase II. Is there a download or upgrade to the 1065 to be able to pick up DaneCom using P25 Phase II, or do I have an obsolete scanner yet again?
Look at the Dane County system in the database:
https://www.radioreference.com/apps/db/?sid=7616
The system
is P25 Phase II capable. But looking at the talkgroups in the database, all but a couple are labeled as
Mode D, In other words, they are using P25 Phase I. As long as the database information is correct, you would be able to receive most of the talkgroups with your WS1065. If, at some future date, those Mode
D, P25 Phase I, talkgroups are transitioned to use Phase II, then at that point, you would lose the ability to monitor them. There are a number of law enforcement talkgroups that are encrypted. Those are designated in the Mode column as
DE. The
D means P25 Phase I, and the upper case
E means full time encryption. If encryption was reported as being used only part of the time, that would, instead, be a lower case
e. No scanner is able to monitor encrypted transmissions.
