Why does MOTOTRBO cause chopper/motorboat/jackhammer sounds?
KD2FLO
Why is it that my MOTOTRBO radio appears to interfere with a bad speakermic causing my audio to have that sound but not with a /\/\ branded one? Same goes for the MD-380, but with a speakermic people recommended online as not having this problem?
In addition, why is it that this is only a problem for MOTOTRBO and not FM, AM, P25, and pretty much every other modulation?
MotoTrbo and a few other modes, like P25 phase 2, use TDM, or Time Domain Multiplexing. This is where (in simple terms) the radio only transmits in certain timeslots, not 100% of the time. This results in the radio rapidly switching between transmit and receive very quickly. This pulsed energy comes across as the motorboat sound you hear. You can often hear this if you hold the radio close to a computer speaker and transmit. Your GSM phone will do the same thing.
Likely cause is there is an issue with the speaker mic, either not proper shielding or something missing/damaged that is allowing this pulsed RF energy to get into the speaker.
Cheap Chinese speaker mics may be an issue if they really are not designed for this sort of environment. Sounds like your Motorola mic is.
FM, AM, P25 phase 1, NXDN, etc. will all do this, but since it isn't TDM/pulsed RF, it'll usually only pop in a speaker when you first key up.
N4KVE
PALM BEACH, FLORIDA
The $4 speaker mikes have no shielding, & are garbage. Running right by the antenna, it picks up the pulsing of the radio. Try the same garbage mike with an external antenna, & the noise won't happen. Just buy a proper speaker mike.
AK9R
Central Indiana
Still, personal attacks on an individual person are hitting below the belt.
Folks, Mars_P25 has received a temporary ban until other moderators can deal with his personal attacks in this thread.
mikewazowski
Forums Manager
Oot and Aboot
Thread cleaned up.
People, instead of feeding the troll, report the post and move on. There's nothing more frustrating than seeing people engage him which leads to a much larger clean up job.
N4GIX
Hot Springs, AR
Mike, I apologize for being one of those who fed the troll. Now that I know where the "Report" icon is located, I'll use it in the future.
I know quite well the amount of work involved, as I've been a Global Moderator at two of the world's largest "flight simulator forums" for almost twenty years... ;)
