Windows Media Encoder question
squadman
Lebanon, PA.
Working on setting up an online feed with the following set up,
Windows Media Encoder 9
Fast-Serv server
My question is what are the best settings for compression and processing?
Thanks in advance
kc8qch
Cincinnati, Ohio
You can adjust the volume coming from the microphone/line in down and turn up the audio on the scanner. Otherwise you have to live with it. It's something not grounded I think in the sound card. I have the same problem withg a couple of my feeds from time to time and i find that a reboot of the server will fix it for while...I also seem to find it sometimes when I tried to spilt the audio to too many feeds (I have a couple of Feeds I use 3 or 4 different ways to feed the audio to the Net.)
w2lie
New York DB Admin
Long Island, NY
are you using a mono cable ?? I fixed a few hums by not using stereo connections (since its only mono anyway!!)
mkescan
Milwaukee
Most people only get hum if they use mic in,try using line in.
Also try turning volume down like kc8qch mentioned.
