WISCOM 800 (2025) Thread
werinshades
Chicago , IL
Which is the same as the current EFJ system, so no major scanner programming changes in that regard.
Same frequencies or same programming method? Figured if anyone is close enough and was wondering which frequencies to program, I'd pass it on. Just the 4 FB2's is all that's needed.
OpSec
Monitoring the database
Same method. Freqs will be different.
Only Motorola has locked/set control channels.
Tim
Milwaukee, Wi
It appears like the system is starting to come alive. I logged the following from Waukesha County with DSDPlus while passing through the area.
2026/05/23 23:00:37 Freq=852.662500 NAC=003 Current site: 3.3
2026/05/23 23:00:37 Freq=852.662500 NAC=003 Current network: 92779.001
2026/05/23 23:00:37 Freq=852.662500 NAC=003 Current site: 92779.001-3.3
tim
BrightAntenna
Bristle with the energy!
East Central WI
I started to program a WISCOM800 system from scratch for one of my SDS200s and the next week they had a start on the system in the Uniden/RR database. So I scrapped mine and appended the RR system to my favorites file.
I didn't expect to be able to hear anything from my home in the Fox Cities but I thought maybe I'd have a chance at receiving the Graham Corners site from my property on Lake Winnebago (NE corner). Initially I didn't see any signal with my indoor-mounted Radio Shack discone but I wasn't too surprised given that some discones struggle with "distant" signals around 800MHz but I left the scanner searching anyway for a few days. No luck.
Today I dusted off one of my two WinRadio AX-31B indoor log periodic antennas thinking it might work a bit better in the 800MHz range (and with some directional gain). To my surprise, I not only received the Graham Corners site but also Rubicon. I actually caught some test comms on TGID 63003 (from memory, I have to check recordings to reconfirm).
I left the scanner running and recording so I'll see what else I might catch. I realized after I left that maybe I should have set the scanner in "Discover" mode because I might capture more detailed info in the logs. I'm running the antenna preamp on a 9V battery so that will die after 20 hours or so. I want to figure out a more robust mount setup for the antenna and then I'll connect it to a continuous 9V power source. Maybe I will switch the scanner to Discover mode at that time.
I should add that I think I also caught a callsign of whoever was testing today. I'll note that too when I review the recordings.
BrightAntenna
East Central WI
TGID 63003 callsign correction (thanks to kf8yk) to WSMZ415.
WSMZ415WISCONSIN, STATE OF0002689628PWActive05/27/2036
Also getting TGID 64001 with UIDs 9940512, 9960505, 9960512, 9970510, 9970512, 9979115. I haven't listened to the recordings yet. I swapped out the 9V battery and left the SDS200 running in Discovery mode.
I'm apparently not getting anything from the Graham Corners site even though that one is strongest for me. Unfortunately I left Discovery mode running on that site. I am receiving most of the traffic on the Rubicon site with a couple of hits from the Milton site.
BrightAntenna
East Central WI
The TGID 64001 transmissions also sound like possible State Patrol. They were talking this morning between 6:30am and 7:30am about a pirate FM station, 88.3 Radio Free Eustaceford (or something like that), and separately about a guy that was spreading manure a bit too heavy yesterday but seemed to be spreading it a little lighter today. Not sure if they were really talking about literal manure.
They did mention some highway numbers and roads. My impression initially was somewhere outside the Milwaukee metroplex but could also have been Madison. I'll have to come back to it for a more thorough review.
The NACs came up as 0x081 a couple times and 0x035 most of the time.
werinshades
Chicago , IL
The license you linked to was on the VHF band. I thought this thread was about the new 800Mhz system?
BrightAntenna
East Central WI
Yes, I'm receiving the Graham Corners site and the Rubicon site. Also caught two transmissions from the Milton site. All from the northeast shore of Lake Winnebago, fairly distant from all of these sites. I haven't determined the straight-line distances yet but I'll guess between 30 to 70 miles, possibly a bit further to Milton site.
werinshades
Chicago , IL
The system is on line now or just specific areas? I programmed the Kenosha site since I'm in Illinois and make my way up I 94 now and then. Those are all 700Mhz sites.
BrightAntenna
East Central WI
It seems they're in the early stages bringing the system up for southeast WI. I initially programmed the system myself to include just the Graham Corners site (all ~850MHz). Recently I saw the system included in the RR/Uniden database update so I scrapped mine and used the official database system.
The Graham Corners site is closest to me but I haven't received any transmissions (other than control channel data) from it yet. Most everything I've received is from Rubicon site but I also caught two transmissions from the Milton site. Maybe they're 700MHz, I'll have to check.
BrightAntenna
East Central WI
Still no traffic received by my Lake Winnebago scanner from the Graham Corners site.
I got the AX-31B antenna wired up to a continuous 9VDC power source (versus the prior 9V battery w/limited life) and rigged up a "mount" that allows me to manually point toward southeast WI and the active sites. Nothing from Rubicon or Milton sites since I messed with the antenna.
Yesterday I logged traffic from the DOC Milwaukee (NAC 0x005) site with the following TG/UID values:
TG4968/UIDs 4000052, 9453080, 4000053, 9453096, 9453327
TG4614/UIDs 4009654, 9283830, 9283527
TG4334/UIDs 4000053
This traffic was logged between about 10:49pm and 11:08pm CDT last night (8/3). The traffic sounded like typical first responder dispatch and responses.
I haven't had a chance to cross these TGs and UIDs with the existing WISCOM data, something I'm curious to check. One of the transmissions on TG4614 mentioned Whitewater. Some of the others mentioned places and street names.
BrightAntenna
East Central WI
After nothing for a couple/few days, I got several hits on WISCOM 800:
8/7
Appx. 1:30pm CDT
Site: Graham Corners NAC 0x037
TG: 64001
UID: 9960508
8/9
Appx. 1:40-1:42AM CDT
Site: DOC Racine YOCF NAC 0x017
TG: 9015
UID: 1106529, 1904384
8/10
Appx. 6:58AM CDT
Site: Rubicon NAC 0x035
TG: 64001
UID: 9960511
