tvengr
Well Known Member
According to the 2 new talkgroups in the database for the WMATA P25 system, you can calculate the remainder of the TGID's for P25 talkgroups by looking at the P16 talkgroups and dividing the TGID's by 16.
All Motorola Type II systems must have a TGID spacing of 16 or multiples of 16, beginning with 16. There are status bits for each talkgroup. For TGID 16, TGID's 17 through 31 control certain functions. For instance, TGID 16 is the normal talkgroup, TGID 17 is all talkgroups, and TGID 18 is emergency. Since the Motorola normal TGID's are spaced by 16, you can keep the P16 talkgroup names and divide the P16 TGID's by 16 and the P25 TGID's will appear sequentially. For example, P16 TGID's 16, 32, and 48 become P25 TGID's 1, 2, and 3. Since most of the P16 TGID's on the WMATA system are spaced by 32, the converted numbers will be every other odd number:Is there a reason behind the “divide by 16” logic?
| Dec ID + # | Usage |
| ID+0 | Normal Talkgroup |
| ID+1 | All Talkgroup |
| ID+2 | Emergency |
| ID+3 | Talkgroup patch to another |
| ID+4 | Emergency Patch |
| ID+5 | Emergency multi-group |
| ID+6 | Not assigned |
| ID+7 | Multi-select (initiated by dispatcher) |
| ID+8 | DES Encryption talkgroup |
| ID+9 | DES All Talkgroup |
| ID+10 | DES Emergency |
| ID+11 | DES Talkgroup patch |
| ID+12 | DES Emergency Patch |
| ID+13 | DES Emergency multi-group |
| ID+14 | Not assigned |
| ID+15 | Multi-select DES TG |
Thank you for the education.All Motorola Type II systems must have a TGID spacing of 16 or multiples of 16, beginning with 16. There are status bits for each talkgroup. For TGID 16, TGID's 17 through 31 control certain functions. For instance, TGID 16 is the normal talkgroup, TGID 17 is all talkgroups, and TGID 18 is emergency. Since the Motorola normal TGID's are spaced by 16, you can keep the P16 talkgroup names and divide the P16 TGID's by 16 and the P25 TGID's will appear sequentially. For example, P16 TGID's 16, 32, and 48 become P25 TGID's 1, 2, and 3. Since most of the P16 TGID's on the WMATA system are spaced by 32, the converted numbers will be every other odd number:
WMATA P16
34416 Shady Grove 1
34448 Shady Grove 2
WMATA P25
2151 Shady Grove 1
2153 Shady Grove 2
It is very easy to convert the P16 TGID's to P25 TGID's by dividing by 16. That is why it is often done when a P16 system transitions to a P25 system. That is why you will see every other TGID on many systems. This is all speculation based upon prior experience. I have no inside information on how it will be done.
Status Bits
Dec ID + # Usage ID+0 Normal Talkgroup ID+1 All Talkgroup ID+2 Emergency ID+3 Talkgroup patch to another ID+4 Emergency Patch ID+5 Emergency multi-group ID+6 Not assigned ID+7 Multi-select (initiated by dispatcher) ID+8 DES Encryption talkgroup ID+9 DES All Talkgroup ID+10 DES Emergency ID+11 DES Talkgroup patch ID+12 DES Emergency Patch ID+13 DES Emergency multi-group ID+14 Not assigned ID+15 Multi-select DES TG
Yep I just reported what I caught while I was in NOVA for a bit.So far, all of the new just listed WMATA talkgroup ID's follow the P16 TGID divide by 16 for P25 TGID rule.
I would suggest trying 2143, 2145, 2147, and 2149. The corresponding P16 talkgroups above the P25 yard talkgroups are currently in use.Has anyone captured any Dulles Yard or Huntington Yard talkgroups?
