I have the scanner loaded with 3 scan lists from Radioreference.com. It appears to be scanning, and every now and then, I get white noise, but I never hear any actual voice traffic. What am I doing wrong?
Thank You! I followed your instructions, and it worked like a charm!St. Clair is simulcast so that will be a problem once you program properly depending on where your at and the tower locations. Garbled audio, missed transmissions potentially.
Towers - STARCOM21 Statewide Illinois Site: St. Clair Co Simulcast
Looking at that text file, while its not a programming file, I can see you dont have any of the digital P25 system programmed, nor any talkgroups. You have all non digital(conventional) frequencies, so of course it wont work on 911 as is.
In PSREdit500 under Import, select Trunked Data. System to do is Starcom21, click Transmitter Site Selection tab, select,
St. Clair Simulcast
On the Talkgroup Selection tab, select all the St. Clair talkgroups you want. Click Import, under Scanlists click #4 since I see you used scanlists 1-3.
Manually:
You can look at the entire Starcam21 system at STARCOM21 Statewide Illinois Trunking System, Statewide, Multi-State
Under Trunking objects tab, put in the control frequencies, 851.225, 851.5625, 852.1625 and set the system type for P25 Auto.
Then go down ~3/4 down at the link for St. Clair county, use the column under DEC for the talkgroup #'s.
I have been to Belleville many times and use a 396XT and it gets the simulcast there quite well.
STARCOM21 Statewide Illinois Project 25 Phase II | Talkgroups 7252 and 8910-8924 used for all communications (as of 9/21) 900 MHz no longer in use. Dispatch has access to other area county talkgroups |
DEC | HEX | Mode | Alpha Tag | Description | Tag |
7252 | 1c54 | D | MedStarMutualAid | EMS: Mutual Aid | EMS-Tac |
8906 | 22ca | D | MedStar 8906 | EMS: Operations | EMS-Tac |
8907 | 22cb | D | MedStar 8907 | EMS: Operations | EMS-Tac |
8908 | 22cc | D | MedStar 8908 | EMS: Operations | EMS-Tac |
8909 | 22cd | D | MedStar 8909 | EMS: Operations | EMS-Tac |
8910 | 22ce | D | MedStar 8910 | EMS: Operations | EMS-Tac |
8912 | 22d0 | D | MedStar BMHE PR | Patient Reports to Belleville Memorial East | Hospital |
8913 | 22d1 | D | MedStar BMH PR | Patient Reports to Belleville Memorial | Hospital |
8914 | 22d2 | D | MedStar SEH PR | Patient Reports to St Elizabeths (O'Fallon) | Hospital |
8915 | 22d3 | D | MedStar 8915 | EMS: Operations | EMS Dispatch |
8916 | 22d4 | D | MedStar St Clair | EMS: Dispatch - St Clair County (some TDMA?) | EMS Dispatch |
8917 | 22d5 | D | MedStar Randolph | EMS: Dispatch - Randolph County | EMS Dispatch |
8918 | 22d6 | D | MedStar Clinton | EMS: Dispatch - Clinton County | EMS Dispatch |
8919 | 22d7 | D | MedStar CarToCar | EMS: Car-to-Car | EMS-Tac |
8920 | 22d8 | D | MedStar Event 1 | Event 1 | EMS Dispatch |
8921 | 22d9 | D | MedStar Event 2 | Event 2 | EMS-Tac |
8922 | 22da | DE | MedStar Ops Enc | EMS: Operations | EMS Dispatch |
8923 | 22db | D | MedStar Emerg | EMS: Emergency | EMS Dispatch |
8924 | 22dc | D | MedStar TRH PR | Patient Reports to Touchette Regional | Hospital |
I am using PSR500 to program the scanner.
Assuming you mean "PSRedit500", there's a PDF direct from their website with an example of how to program a trunked radio systemWhere do I enter this information?
Where did you find this? I am on Radioreference, and cannot find anuthing like this. All I see is that MedStar is part of Starcom21MedStar EMS (MetroEast)
DEC HEX Mode Alpha Tag Description Tag 7252 1c54 D MedStarMutualAid EMS: Mutual Aid EMS-Tac 8906 22ca D MedStar 8906 EMS: Operations EMS-Tac 8907 22cb D MedStar 8907 EMS: Operations EMS-Tac 8908 22cc D MedStar 8908 EMS: Operations EMS-Tac 8909 22cd D MedStar 8909 EMS: Operations EMS-Tac 8910 22ce D MedStar 8910 EMS: Operations EMS-Tac 8912 22d0 D MedStar BMHE PR Patient Reports to Belleville Memorial East Hospital 8913 22d1 D MedStar BMH PR Patient Reports to Belleville Memorial Hospital 8914 22d2 D MedStar SEH PR Patient Reports to St Elizabeths (O'Fallon) Hospital 8915 22d3 D MedStar 8915 EMS: Operations EMS Dispatch 8916 22d4 D MedStar St Clair EMS: Dispatch - St Clair County (some TDMA?) EMS Dispatch 8917 22d5 D MedStar Randolph EMS: Dispatch - Randolph County EMS Dispatch 8918 22d6 D MedStar Clinton EMS: Dispatch - Clinton County EMS Dispatch 8919 22d7 D MedStar CarToCar EMS: Car-to-Car EMS-Tac 8920 22d8 D MedStar Event 1 Event 1 EMS Dispatch 8921 22d9 D MedStar Event 2 Event 2 EMS-Tac 8922 22da DE MedStar Ops Enc EMS: Operations EMS Dispatch 8923 22db D MedStar Emerg EMS: Emergency EMS Dispatch 8924 22dc D MedStar TRH PR Patient Reports to Touchette Regional Hospital
It is on STARCOM21. Scroll down close to the bottom beyond the counties. STARCOM21 Statewide Illinois Trunking System, Statewide, Multi-StateWhere did you find this? I am on Radioreference, and cannot find anuthing like this. All I see is that MedStar is part of Starcom21
Hopefully, one more question:
I was able to import the MedStar data, and I get a chirp when someone keys a mich ( or something) but I never get any modulation. It chirps, and shows MedStar, but no voices. Do I have something set incorrectly?
Oddly enough, no sooner than I posted that question, it came online and is working just fine!
That should be asked in the Uniden Tech or Illinois forums. This forum is for Whistler scanners.I just received my new SDS100 scanner. Can you give me some help on getting my Favorites working on it?
