WS1040 is Silent
ggermain
I have the scanner loaded with 3 scan lists from Radioreference.com. It appears to be scanning, and every now and then, I get white noise, but I never hear any actual voice traffic. What am I doing wrong?
Where are you, what agencies are you trying to listen to, do you get any of the weather frequencies, did you adjust squelch, how did you program the scanner (manually or with what programming software)? We need more information before we can start to help.
ggermain
I am in Belleville, IL, just across the river from S. Louis. I am using PSR500 to program the scanner. I can get the weather frequencies.
I have 3 scan lists (all being scanned), one of which contains local hospital FM channels
Attached is what I currently have in the scanner. I realize that I'm new to this game, but you would think that I would have hit at least one of these :)
  • Scanner Info1.txt
tvengr
Well Known Member
Baltimore County, MD
Please attach your PSREdit500 programming file so we can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file.
Ronaldski
MI DB Admin
Bay City MI
St. Clair is simulcast so that will be a problem once you program properly depending on where your at and the tower locations. Garbled audio, missed transmissions potentially.
Towers - STARCOM21 Statewide Illinois Site: St. Clair Co Simulcast
Looking at that text file, while its not a programming file, I can see you dont have any of the digital P25 system programmed, nor any talkgroups. You have all non digital(conventional) frequencies, so of course it wont work on 911 as is.
In PSREdit500 under Import, select Trunked Data. System to do is Starcom21, click Transmitter Site Selection tab, select,
St. Clair Simulcast
On the Talkgroup Selection tab, select all the St. Clair talkgroups you want. Click Import, under Scanlists click #4 since I see you used scanlists 1-3.
Manually:
You can look at the entire Starcam21 system at STARCOM21 Statewide Illinois Trunking System, Statewide, Multi-State
Under Trunking objects tab, put in the control frequencies, 851.225, 851.5625, 852.1625 and set the system type for P25 Auto.
Then go down ~3/4 down at the link for St. Clair county, use the column under DEC for the talkgroup #'s.
I have been to Belleville many times and use a 396XT and it gets the simulcast there quite well.
Ronaldski
MI DB Admin
Bay City MI
The folder you save it in, the programming file will have a .bin file extension and is 66K file size. That's the file if you wanted to include on here, although there was enough in the text file that I could see what you have and have not-the 911 system.
Again you just need to in PSREdi500, Import Trunked data and do St. Clair simulcast and then talkgroups as mentioned above.
ggermain
St. Clair Simulcast
Manually:
Thank You! I followed your instructions, and it worked like a charm!
ggermain
Next Question:
I'm not having any luck getting MedStar to work.
tvengr
Well Known Member
MedStar Ambulance (of Sparta)​
Additional information in the WIKI
Serves: Swansea, Belleville, Cahokia Heights, East St Louis, Fairview Heights, Freeburg, Lebanon, Washington Park (and possibly more)
Project 25 Phase II
Talkgroups 7252 and 8910-8924 used for all communications (as of 9/21) 900 MHz no longer in use. Dispatch has access to other area county talkgroups
tvengr
Well Known Member
MedStar EMS (MetroEast)​
DECHEXModeAlpha TagDescriptionTag
72521c54DMedStarMutualAidEMS: Mutual AidEMS-Tac
890622caDMedStar 8906EMS: OperationsEMS-Tac
890722cbDMedStar 8907EMS: OperationsEMS-Tac
890822ccDMedStar 8908EMS: OperationsEMS-Tac
890922cdDMedStar 8909EMS: OperationsEMS-Tac
891022ceDMedStar 8910EMS: OperationsEMS-Tac
891222d0DMedStar BMHE PRPatient Reports to Belleville Memorial EastHospital
891322d1DMedStar BMH PRPatient Reports to Belleville MemorialHospital
891422d2DMedStar SEH PRPatient Reports to St Elizabeths (O'Fallon)Hospital
891522d3DMedStar 8915EMS: OperationsEMS Dispatch
891622d4DMedStar St ClairEMS: Dispatch - St Clair County (some TDMA?)EMS Dispatch
891722d5DMedStar RandolphEMS: Dispatch - Randolph CountyEMS Dispatch
891822d6DMedStar ClintonEMS: Dispatch - Clinton CountyEMS Dispatch
891922d7DMedStar CarToCarEMS: Car-to-CarEMS-Tac
892022d8DMedStar Event 1Event 1EMS Dispatch
892122d9DMedStar Event 2Event 2EMS-Tac
892222daDEMedStar Ops EncEMS: OperationsEMS Dispatch
892322dbDMedStar EmergEMS: EmergencyEMS Dispatch
892422dcDMedStar TRH PRPatient Reports to Touchette RegionalHospital
ggermain
Where did you find this? I am on Radioreference, and cannot find anuthing like this. All I see is that MedStar is part of Starcom21
ggermain
Cool! Thanks
Evidently, something didn't import properly the first time. I went back and imported the MedStar data all by itself, removed everything from the radio, and just uploaded the MedStar data, and it works. Then, I imported the rest of the data, and uploaded it all to the radio, and everything seems to be working.
Thank you all for your help!
Hopefully, one more question:
I was able to import the MedStar data, and I get a chirp when someone keys a mich ( or something) but I never get any modulation. It chirps, and shows MedStar, but no voices. Do I have something set incorrectly?
SOME talkgroups/radios are using Phase II on the system, without seeing the system, nor knowing for sure, I'll suggest the possibility that is the issue.
ggermain
Oddly enough, no sooner than I posted that question, it came online and is working just fine!
Just something to think about, read the notes on the Starcom21 RR database page, Phase II radios may switch between P-1 and P-2, so sometimes it may work sometimes it may not. Might be a good time to start saving up for a Phase 2 scanner if Starcom21 is your interest.
ggermain
I just received my new SDS100 scanner. Can you give me some help on getting my Favorites working on it?
