Ansted 2-033 neighbors shows
1-014 Elmira
2-001 Malden
2-026 Alderson
2-029 Kopperston
2-030 Pax
2-036 Glen Jean
Thanks, Jeff. I appreciate you going through the trouble!
Take care,
Mike
1-014 Elmira
2-001 Malden
2-026 Alderson
2-029 Kopperston
2-030 Pax
2-036 Glen Jean
Well Hello Everybody, Today I had to go to Clarksburg for a Dispatcher class. While being a passenger I had the chance to check the WVSIRN sites along I-79. It was a lot of fun. Starting off, before leaving Kanawha County, I check the Clendenin site 2-004, running good. Then the Elmira site 1-014, running good. While passing the 19 South exit on I-79, I picked up Webster Springs site 1-035, running good. Next the Gassaway site 1-024, running good. Then there was nothing on the Flatwoods site. I come on up to the Burnsville site 1-013, running good. The Weston site 1-036 was running good but the CC was on 453.26250 instead of 460.23750. So I changed that in the Data Base. Meanwhile the Buckhannon site 1-037, was running good. I started picking up the Phillippi site 1-019, good signal but the site number would not come up on my Pro-106. Also while passing the 99 mile marker ( Buckhannon Exit ) I picked up the Elkins site 1-022, good and clear. Ok then there was the McWhorter site 1-012, was running good. At this time I started picking up the Salem site 1-005, running good. Then I was picking up the Mannington site 1-018, it was coming in at at 3 bars. Finally the Clarksburg site 1-001, nice and clear. It was a good trip up and back, Lots of radio traffic and beautiful weather.
Bubba did a fine job and I understand that Braxton County supposedly is on line with the SIRN. Although I cannot say for certain if they are simulcasting old legacy stuff or not.
After a lot of damn tinkering I finally got unitrunker going OMG to me
It appears that the 1st of the New Year will bring some changes to the radio nets in WV (and maybe nationwide). The rumor has it, Fire & EMS operations may be leaving the P25 system because of operational issues. Based on some of the scuttlebutt circulating, and the confirmed action of Berkeley Co’s re-programming of their pagers and radios to Low band operation, effective 1/1/13. BC Central has also started simile-casting LE “all-calls” on SP’s low band channel (42.10 MHz).
Based on conversations, folks are saying it is the result of a change in DHS’s inoperability needs and the P-25 failures that have been found.
Anyone with any information?
