WV Interoperability System
c_gutta
Columbus, OH
I have the new Radio Shack Pro-106 (same as the GRE PSR-500). Is there any mods I need to make to the Win500 settings when importing this system from Radio Reference? I remember reading something about settings using Win96 and Uniden scanners.
Thanks in advance.
OldDeadOne
Silent Key
Fayetteville,WV
Heard some "testing" MOT 00047 this morning,anyone have a idea where this might be? the talk was kind of short and no location was given
wm8s
Houston, TX
Not sure what you mean by MOT. If you mean talkgroup, my computer says that T/G 00047 is the EMS radio techs.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Thanks in advance.
Guess no one answered.
If you can hear a system control channel, set system Type to P25 Auto. If you can't hear a CC, it will still set the correct Trunking Tables when you roam into range. Or in this case, you can also preset the tables by setting Trunking Tables from Default to Custom then open the Trunking Tables button and set as follows:
Code:
#00  8192 12287  8192 453.0250 12.50
#01 12288 16383 12288 450.0000  6.25
paul1
WHEELING WV.
Ohio Co Freq's Active
Paul1 here
Wheeling is my turf and today i have been hearing traffic associated with the WQCL307 LICINSE
THERE ARE ABOUT ten freq's associated with this licinse also started hearing the bci traffic on155.1300
ct 88.5 s on my psr500 hopes this helps .Paul1
OldDeadOne
Silent Key
Fayetteville,WV
Got another on the wvirp but isn't in the database: 9342 and it sounds like sheriff's(was doing a traffic stop),anyone got a clue for this one?
OldDeadOne
Silent Key
Fayetteville,WV
So finding who's behind a talkgroup is hard sometimes? I've wondered how some of those id's that are listed(either conventional or trunked) be tagged. That talkgroup 9342 comes in loud and clear and I've been hoping someone says something to let me know the general area or what agency is using it. I like it when something new pops up in my Pro 2096 :p
BM82557
Berkeley Co WV
Jefferson County TG 4915
4915 is active @ 1950 local.
1536 @ 1954
1507 - test count @ 1958
1536 @ 2004
1534 @ 2005, echo on the voice comms
1534 @ 2006 - somebody asking chief whats displayed on his radio, he says 151501, other party says thats Engine 1
1539 @ 2010
1513 @ 2011 -- encrypted
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
It takes some time and a lot of people working together, that's what makes this site the best of its kind. For the WVIRP, a lot of the TGs follow a pattern...the one you listed is probably state related. Just keep monitor it and let us know. If you can, hold on that channel and record anything you hear on it. that way, you can go back and listen.
mike_s104
1536 @ 1954
1536 @ 2004
1539 @ 2010
I caught 4915 as well. There is a 4935 listed as radio techs, so maybe that's what it is.
wm8s
Houston, TX
1536 @ 1954
1536 @ 2004
1539 @ 2010
He's referring to a radio ID. If you're running Unitrunker or had a scanner the displays RIDs, you'll see that 151501, too (which apparently is the RID that's programmed into the radio that's bolted into Engine 1). [E.g., you can program the PSR-500 to display "Engine 1" whenever that radio is transmitting.]
I think 09342 is WV SP Troop 7 / Turnpike Dispatch and 04915 is Region 5 Tac-1. The Turnpike was using 09021 for a while. It looks like they're switching to TGs 0934x and RIDs 94100-94200 (although the console that's patching the VHF system onto the IRP right now is reporting RID 00000000).
What in the world would possess a county to encrypt fire traffic? I'll never quite understand this.
wm8s
Houston, TX
BTW, for those counting these sorts of things...
I now show 750 talkgroups that have either been keyed up or are almost certainly assigned, and I've recorded 2,327 different radio IDs, mostly on tower 0109/Garfield (Kanawha/Charleston) (so this doesn't take into account much at all from the two most active areas of the state [the HARR/MARI/MONO corridor, and the eastern panhandle]), with a total of about 3,800 likely assigned RIDs, if the patterns hold out. Yikes.
Now let's see.... (3,800 radios x $5,000/radio, installed) + (50 sites x $???,???/site) = .... a lot of fire trucks and cruisers!...
mike_s104
I'm sure they got a big discount for all of them :)
