There is something wrong with the station per the other post. On reddit, somebody said they could not get SAME decoding working, which is a major problem if it has to do with the site.I am in Salem using a Diamond dual band antenna it comes in distorted here also. Depending upon the time of day it changes and sounds ok.
If you have the waterfall option when it is selected AUDIO comes in perfectly. I have notified Joe Bearcat a Uniden rep. about this issue.
I have tried every filter there was no change. In waterfall mode audio is great and little noise. Running latest firmware no change from initial waterfall firmware. I can listen to 162.500 Mt Washington completely readable in waterfall mode and all distorted in normal scan mode . I hope they fix this. I also found this problem listening to weak ham repeaters. Also in waterfall mode I can shift it to all weather freqs and have no problem, audio is fine. This happens on 162.425 in Gloucester also for me, distorted on scan clean on waterfall.
I'm listening from Concord and it has slightly distorted audio but readable with good signal using a SDS200. I checked and verified the same with BKR and Motorola APX portable radios. It appears it has something to do with the audio at the site.
I listened again and yes 162.4 audio is slightly distorted you are only 8 miles from the site I am about 40 miles south. I was wondering do you have the waterfall add on on your sds200? If so could you listen to distant weather frequencies on scan mode and compare your results using the waterfall mode 360khz span mode auto gain. I find that sensitivity and general reception on the weaker signals is much better in waterfall mode. In scan mode on the sds200 162.40 is almost unreadable and distorted yet waterfall mode it comes in fine I have tried all filters to no avail. My son lives near where you were on Millstream I have been retired for some time myselfI'm listening from Concord and it has slightly distorted audio but readable with good signal using a SDS200. I checked and verified the same with BKR and Motorola APX portable radios. It appears it has something to do with the audio at the site.
John
I have it set to FM for weather not much change on my end . Going into waterfall mode it goes to NFM and sounds much better and far less noise . Only on WEAK stations strong stations not much difference . But 162.400 audio is distorted slightly Not off freqOne other thought. I just got an SDS100 yesterday and noticed that our local WX station sounded pretty poor. However, the SDS100 defaults to NFM for the WX channels. Changing it to FM made it sound much better.
I did this a few months ago, going to all the trouble of specifying my receiver and observations, only to get on a meaningless email exchange with a very non technical govt employee. I offered to send a recording of KZZ40 (clean) versus WXJ40 and did not get a response.You can report outages/issue on this webpage/phone number/e-mail:
1-888-886-1227NWR Outage Report
www.weather.gov
nwroutage@noaa.gov
Thats a good sign that the deviation is exceeding +/- 5khzI have it set to FM for weather not much change on my end . Going into waterfall mode it goes to NFM and sounds much better and far less noise . Only on WEAK stations strong stations not much difference . But 162.400 audio is distorted slightly Not off freq
I quoted the wrong post and cannot find the edit/delete option. I was responding to the post thstcsaid thexstation sounded much better in (wide) FM mode. Thats my experience.Thats a good sign that the deviation is exceeding +/- 5khz
I have Listened to it the audio is slightly distorted FM or NFM not off freq or over deviated . I initially thought it was signal strength ,its not bad but compared to 162.450 its slightly raspy but I am 40 miles from Plausawa Hill in Pembroke NHNarrowband is 2.5KHz deviation. NOAA stations use 4 or 5, I forget which. So narrowband is not the correct setting for them. My point was that if the OP is listening using NFM, it could be worsening his perception of whatever the actual problem is.
