Those are likely going to be switching voltage regulation smd inductors for the various logic devices.
Ya, I am being generous and assuming there are more on the other side of the PCB, but ya, that’s also likely, which furthers my point… If you aren’t connecting any accessories, I believe that you can create a robust solution, but if you plan to use a variety of accessories and/or external I/O, just heed this warning…
Personally, I followed the instructions in the manual for making a headset connection and I used that to create a headphone output (unbalanced line level inputs handle it well too!) and I have a sound card interface connected to input 1 set to Alt. PTT. So I need the accessories to work reliably.
I’m lazy and like screw terminals… so I’d use that part. I don’t know the exact part number you’re referring to regarding the 44:25 cable, but AFAIK, that is not the same pinout. The 44pin does not carry canbus.
The XL-200M HHC plugs into the 44pin on the back of the MRU AFAIK… It’s a color screen version of the current 731, but with a 44 pin connector at the end instead of a 25 pin.
-B
