XG25P and XG25M no Transmit
70cutlass442
We have had our P25 system up for a couple of months.
Our fleet of XG25P and Ms all do this... If the user keys too soon, such as during hangtime (less than 300ms), the Harris gives an unfamiliar beep or chirp when pressing the PTT button, and then transmits NOTHING.
I have TX buy option unchecked in RPM2 which should not stop it from transmitting when there is a carrier. Does anyone have a solution?
70cutlass442
Update:
Our dealer reviewed the programming and they too are confused. This is an issue with the entire fleet and not just one or two radios. We also noticed that if the user tries to transmit "over" someone else, the radio produces that unfamiliar beep, but then continues to receive the other user.
Our dealer will be reaching out to Harris to learn more. I will try a similar program in an XL200P next week and see if it has the same issue.
70cutlass442
What kind of system is this? Trunked or conventional? Repeated or simplex? Analog or P25? Encrypted? Curious to know the details and outcome!
-B
This is a two-site conventional P25 system. Portable units utilize "vote scan" to select strongest transmitter while the repeaters use a distributed voting protocol to select strongest receive. No encryption. I thought the vote scan was creating a problem but the issue is the same on mobiles which do not use that feature. Everyone is at a loss on this so far!
wa8pyr
Staff member
Lead Database Admin
Ohio
Update:
Radios going 'boop' and not transmitting if another person is talking is intentional and probably part of the P25 protocol; it's so one user doesn't walk on another user. This is the same behavior I see on our system (which is P25 trunked).
Since you're using a P25 multicast system with vote scan, and it's happening on an empty carrier with no one talking, I suspect some kind of timing issue.... just a WAG on my part.
Your service techs may need to escalate this to Harris TAC to find a solution.
Tom
merlin
DN32su
My best guess here is the hang time is too short. 2000 to 3000 Ms is usually what I see.
Sshould be looking into your site vote scan timing also.
