XL200
junior71
I’ve assigned user alias for radios ID’s however the aliases are not showing up only the radio ID’s are when the radio receives. I’ve tried and tried to figured out what setting I’m missing. Any help would be greatly appreciated.
K2NEC
NA
You have to assign the individual call set in the system options
K2NEC
NA
I'm not exactly sure, I don't have nearly 255 entries in my ICALL/Alias list
Where do you see user alias list?
rjschilder
AES FTW
Do you have a Harris sr10a core? The UAS should push aliases automatically to xl radios on top of p25 audio. No need to program anything in the radio.
rescue161
KE4FHH
Hubert, NC
Can you please elaborate on this? We have a 10A4+ and would like to do this, but only the RID shows up on the screen of the radio. Voice End User and Subscriber Units are fully populated with the names that we want to display.
rjschilder
AES FTW
It's actually an sr10a.7 feature. The MASTR V's at each site have to be running r19 code, but basically there's a UDP port that it opens and pulls the UAS alias in addition to the radio ID. If you look in rpm2 there's an option for 'Prioritize In-Band Alias'. If you tick that box it will hold off on displaying the radio ID and only display the alias. All XL model radios support this feature.
Edit: just for clarity, it displays the UAS alias for the voice end user
rjschilder
AES FTW
Just adding that the aliases do show up on the consoles, but the radios themselves.
This is also true, symphony consoles will display the radio ID for sr10a cores. Like I said above, sr10a.7 and r19 BBM code will get you radio aliases on all XL radios as well.
FJB2022
Where is "Prioritize In-Band Alias"? Can't seem to find it anywhere.
junior71
Can somebody explain what the user alias list is for in RPM2? Unfortunately the agencies I’m monitoring do use the function mentioned above. So I have to manually enter the ID’s.
