XPR 4550 and cps not working
Kenilworth IL
hi
i have cps 16 build 828 and its not working with my 4550. it used to work and now it says that it cant find the device. i tried a different computer and its still not working. any help would be great
K2NEC
NA
What kind of cable and what changed between it working and it not working
K2NEC
NA
That's not helpful
Is it the front GCAI cable, or the rear 26 pin cable?
Were any windows updates installed, any new drivers? Any new CPS installs?
Have you tried running in admin?
Simply saying "it worked and now it doesn't" doesn't help anyone try to solve your problem
k7gdm
Great Falls, Montana
hi
In response to your inquiry regarding your 4550, you need to get a copy of CPS 2 by Motorola. I think the other CPS that may help, CPS 1 or 116. it sounds like an update will help. I’ll assume you already know that it can only be programmed with full access via rear port?
You may have to contact Motorola Solutions online. They will likely charge you for registration of software but you’ll get plenty of functions. I have a vhf and a uhf in that radio. BTW, port drivers are not a problem? I hope this helps and write me with any questions.
Dave McCracken-k7gdm
DMR ID is 3143914
DMR repeaters: 442.800 CC 2 and 146.800 CC 2.
Hytera RD982’s with mixed mode analog and DMR
Both Tied into Mac Pass Repeater Group (MPRG 1) 31301 on time slot 2 with time slot 1 tied to Mike’s Place, group number 3145153 and soon to be on TGIF and All Star Link system.
Great Falls, MT
www.qrz.com/db/k7gdm
KevinC
Encryption
I'm everywhere Focker!
In response to your inquiry regarding your 4550, you need to get a pay of CPS 2 by Motorola. I think the other CPS that may help, I believe it’s CPS 1 or 116. it sounds like an update will help. I’ll assume you already know that it can only be programmed with full access via rear port.
Both Tied into Mac Pass Repeater Group (MPRG 1) 31301 on time slot 2 with time slot 1 tied to Mike’s Place group number 3145153 and soon to be on TGIF and All Star Link system.
Great Falls, MT
MOTOTRBO (as well as APX) CPS has been free for a couple of years now.
cmjonesinc
DMR ID is 3143914
Great Falls, MT
If it was last programmed with v16 it can remained programmed with v16. Cps2 has some advantages but isn't necessary depending on what the last program version was. If the old cps meets your needs I would not recommend updating to cps2. It's way slower and clunky. Both are a free download with a free motorola account. You can absolutely program with the front port. I have two 4550's on my desk right now. If you're needing a wideband entitlement I don't think new licensing for cps 1 is available. For cps 2 it cost $5.
RadioGuy7268
PA
I have seen the front programming jack fail on 4550's. Try using a rear cable (making one yourself is a 10 minute job if you have the 26 pin rear connector already.)
If you have another 4550, you can try swapping the front housing and see if it works.
boomer
Dallas
I’ve run into a recent issue I’d never experienced before with XRP6550 not reading, radio shows Impress when cable is connected, CPS beeps when a radio is detected, but wouldn’t read it. Looked in Windows Device Manager, could see a MotoTRBO radio but with warning sign. Looked under Advanced and it wanted an IP address. Added 192.168.11.1, then warning sign went away and CPS could read radio
