XPR3500e
Dave_151
Sacramento, Ca.
We use 20 Motorola XPR3500e radios in our 3 story plant for our maintenance employees. I have 2 questions.
1. Is it possible for me to call a number from my home phone or my cell and talk to anyone of them on their radio?
2. Is it possible to give all 20 radios a lunch tone at a certain time to notify them of their upcoming lunch break?
Thanks for any help.
Dave
K2NEC
5F6
The short and simple answer, no to both
K2NEC
5F6
1. Requires a rather complex system to incorporate phones. I'm not even sure that 3500s support it
2. Can be achieved with quick call or an all call on digital. But if you mean a local alarm that goes off on the radio, no it's not possible.
Dave_151
Sacramento, Ca.
Hi, I was wanting to be able to talk to any one mechanic if needed even If I had to get a completely different radio setup.
As for the lunch tone we are in California and they HAVE to punch out for lunch before the 6th hour or we pay them a penalty.
Thanks for all your help.
Dave
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Dave,
Yes there are systems that can accomplish this. You may be looking at replacing the radios in order to do calls with a Teldio system and R7 radios or similiar. A tone can be scheduled with a software system or an office person pressing a button on a MCD5000 to send the tone.
That being said, I have worked maint in a plant and I would use administrative controls for this where the maint folks are required to clock out in staggered times from the 4-5.5 hour mark in order to keep from having to pay the penalty. Use the supervisors/team leads to keep tabs on who clocks out.
If you use a tone, many will say they didnt hear it or were in the middle of something and forgot. TT
Firebuff880
Boynton Beach, FL
Dave,
As TampaTyron posted the answer is yes, but it depends on your budget. I have built a couple of these and Telephone inbound is much simpler than Telephone outbound. Also, I am not at all sure that you can do this with 3500's as I have only done it with 7500's. In my case, it was a high-end hotel/conference center and the request was that anyone could pick up a house phone and by entering a four-digit extension be connected with the A/V Talk Group, the Catering Supervisor, or the HVAC on-call engineer for the conference center.
We needed a repeater for each active Call to be connected as the Telephone support will only use one of the two slots available at any one time. because the repeater has only one 4-wire interface. You also need an EID Feature Code in each repeater to enable the Digital Telephone Patch (DTP) Feature
Then you need the interface to the PBX/PSTN network. In the original announcement of this feature, Motorola says "the DTP utilizes an existing Commercial Off The Shelf (COTS) Analog Phone Patch box for phone operation through the repeater" and they refer to the Zetron M735 hardware in their Powerpoint from the Release 1.8 2011 Announcement.
In my case, we built an Asterisk Box with a modified App-RPT and used the DMK engineering URI USB to 4-wire interface instead of the Zetron. This gave us much more capability to control the call routing both inward and outbound. Unfortunately, the gentleman who did the changes to App-RPT is now a silent key and I am not sure if everything made it back in App-RPT as a patch before he passed, which was the original intention.
If you go this way then a scheduled call file to an extension (talk group) that sends an alert tone maybe followed by an announcement should handle the Lunch break notice.
NOTE: even though your phone call is full duplex the radio side will continue to be Half Duplex, so only one party can talk at a time same as a radio-to-radio call.
Good Luck --
MTR-3000 Part # HKVN4066A
