Xpr5550e Handheld remote
Georgia
Does anyone have experience with the handheld remote control for XPR5550e? I recently purchased a new radio with this option, for the first time, and have noticed the tx audio received by other radios is not very good. It comes in low and very muffled, like the user is in a metal barrel. I have programmed many radios before using cps and am fairly proficient with it. I have tried disabling noise suppressor and toggled off MIC-AGC. I have also manipulated mic gain manually, to no avail. This problem with tx audio is apparent on both analog and digital channels. I was hoping someone here could help verify if this is a normal condition of the product, something that may be out of whack with programming, or maybe a faulty unit. The Rx audio is great and on-par with any other Motorola XPR I have. This just doesn't seem to be what one would expect from Motorola and I've been using them for over 25 years. Thanks for sharing any experience with this product.
K2NEC
5F6
Is there a chance you could post a screenshot of your TX audio settings?
Georgia
Thanks for the reply. Not sure if I can do a screen shot but, Analog mic AGC enabled, Digital mic AGC enabled, Analog Mic gain -7, Digital Mic Gain +4. Vox sensitivity level 2 (not using any VOX accessory), Hot Mic Front accessory.
K2NEC
5F6
Hmm.
What model mic are you using? I know my CDM desk mic sounds very similar to that in the sense that it sounds muffled and low audio, even when I'm right on top of it.
Georgia
Hmm.
Its the PMLN7131_ Mototrbo Handheld Control Head for Xpr 5550e.
N4KVE
PALM BEACH, FLORIDA
The lousy TX audio on a 5550 with the HHCH is normal. 2 guys locally use that combo, & the day they switched to the HHCH, their TX audio went into the toilet. It’s sad this happens, but it happens.
Georgia
Well, I hate to hear that. It’s a great concept and the RX audio is really good. Just seems unlike Motorola to me. I could expect this from some other manufacturers, but I’ve always been pleased with Motorola. Thanks for your reply.
N4KVE
PALM BEACH, FLORIDA
My friend also has a XTL, & APX in his vehicle, & they are both hooked up to HHCH’s, & they sound great. Granted, they are totally different from the XPR HHCH, but the point is they can make a great sounding HHCH if they wanted to.
Firebuff66
CT
Our EMS service has a few and they sound great, If I could afford the HHCH I would upgrade mine
Georgia
Amen to that. The bad part is, the Rx audio is as good as you could expect. I wouldn’t have noticed had someone not told me, but it’s bad.
jason51
Dallas
I have one and it sounds great. It is all in the programming. It takes some tweaking.
Georgia
I have adjusted mic gains with AGC disabled. Also disabled noise suppressor, but still sounds muffled and the tone is not anything near any other xprs. Could you suggest where I should look elsewhere? Aren’t mic gains where I should be concentrating or is there another parameter that controls this? Thanks for any advice.
Firebuff66
CT
I would suggest reading this PDF & Thread and see if it can help How to fix MOTOTRBO subscriber audio
N4KVE
PALM BEACH, FLORIDA
Both my friends read the article, & have recent FW. Simply, when they use the regular mike, & control head they both have excellent TX audio. When they switch to the HHCH, they don’t. Now it’s not horrible, but it’s definitely not crystal clear. And that HHCH costs as much as a 5550.
