XPR7550e DMR
tbille
South Easton, MA
Hi Everyone,
I have done quite a bit of work on the APX and XTL line of radios, but I have not dabbled in DMR. Let me preface this with that I am no expert and I'm currently in school for criminal justice and I find radios very interesting; Im learning, so I apologize for any incorrect terminology. :)
I purchased a MotoTRBO XPR7550e about 6 months ago to be able to listen to the campus safety where I go to school along with some surrounding agencies. I had programmed in two DMR frequencies and everything was great! I was able to receive them perfectly. The radio and all frequencies were in RX only mode for the exception of some GMRS frequencies.
Then I got ambitious and trued to add a few more. I programmed them the "same way" and then all of a sudden I was no longer receiving any audio from any DMR frequencies. Analog frequencies were working fine, that's what I'm familiar with.
I have some friends that do volunteer work and are employed with agencies from home. They have been helping me as I learn everything. They were willing to take a look at my cqodeplug and were unable to find anything wrong.
One suggestion was to change the radio ID as the system may have recognized it and blocked it.
I have also done some reading into RAS, but I am unclear if it applies to a radio that is only trying to receive, not transmit.
Any suggestions of what I could try next?
Thanks in advance!!
tweiss3
Is it time for Coffee?
Ohio
This sounds like RAS. If RAS is enabled, while not encryption, your radio won't play the audio without the correct RAS key. You can listen with a DMR enabled scanner, but the commercial radios won't let you listen to RAS enabled transmissions.
tbille
South Easton, MA
That’s what I figured.
Is there a way to determine if the system has RAS in the future?
I have an SDS100 and I plan on buying the DMR capability soon.
Thanks so much!
