XTL TPT?
APX8000user133
Saw a video on facebook of a guy showing the TPT of an XTL 2500 and an APX 7000. And I was wondering how he even got that on the XTL?
nokones
Sun City West, AZ
I'll check all of my various RSS and CPS applications and see how far back TPT is/was used. I believe TPT is only associated with PT-T ID MDC and/or DTMF Signalling and Trunking. Also, I will check and see if it was a box to check for non-PT-T MDC features and and Conventional systems.
K2NEC
5F6
How does that work? I thought that was only available on trunking or through the XTS FPP hack?
There's a way to make it work on XTL using DVRS. There's instructions online somewhere. For the APX, anything past firmware R31 allows a conventional P25 TPT on Motorola P25 repeaters.
N4DES
Retired 0598 Czar ÆS Ø
South FL
What you are describing is on the XTS portable, not the mobile XTL. This is from the XTS help screen:
N4DES
South FL
It's not a true TPT, but you can always check this in the Secure Advanced tab.
mbnv992
Also known as MT2000 man on Batlabs since 2001+
AZ
I thought you needed FPP enabled in the flash in order for the DVRS trick to work.
K2NEC
5F6
2. The DVRS Method: This method only applies if the user is going to be using a Quantar P25 conventional repeater. In this method, the radio is tricked into thinking the repeater is really a Digital Vehicular Repeater System (DVRS), which it's not. When the radio is operating on a DVRS, it can play talk permit tones to tell the radio user that the DVRS is ready to receive communications. This method doesn't work if you are using an analog repeater or on simplex.
1768066364498-png.195247
mbnv992
AZ
Was thinking the OP wasnt using a Quantar P25 conventional repeater and was just doing conventional simplex / a non P25 repeater. In which case if he was - this TPT DVRS trick wouldn’t work -unless you had FPP in the codeplug
K2NEC
5F6
OP was just asking how its possible on an XTL. There's ways, that one is the one I used.
dickie757
Resolved
Out of range
Regarding XTL tpt, what about a GTR8k instead of Quantar? Just wondering.
I am about to update a small fleet of APX4k w/ fw 37 to allow tpt on a gtr8k. It has been tested, but apx is not xtl.
