XTL5000 transmit tone
SlipNutz15
Wacker
Central PA
I have programmed an XTL5000 that has a tone after the normal MDC1200 keyup (wait to talk) tone. This tone is just a short beep but it's not the short side tone beep because it does it both on MCD and ASTRO channels. It's approx 500ms into the key up.
The system we are using is Analog dispatch and P25 Conventional ops channels. No TRS or anything like that.
Does anyone have any idea where in the CPS this tone is turned on so I can shut it off?
SlipNutz15
Wacker
Central PA
I think I found it under the Secure Configuration, Advanced for the Tx Clear Alert Tones. I will try this option turned off and respond back.
