XTS 3000 programming hardware
topdog1198
topdog1198
I've been programming my 5000 for a little while just made the purchase of a 3000 purchase the software now looking for the hardware interface. I see quite a bit of stuff on eBay but don't wish to waste my time buying junk. Does anyone know where I can get the correct rib box and the cable? I've already purchased one off of eBay it doesn't seem to work I keep getting an error message that is not communicating with the radio, so I'm thinking may be a bad boxer cable any suggestions
Thanks in Advance
parma,ohio
i still use the HT1000 Cable and Motorola Rib Box i have seen people buy a RIBLESS one never had or tried one.
N4KVE
PALM BEACH, FLORIDA
I use a Maxton ribless cable. Kawamall sells the same thing on E-Bay for about $20. Ideally, you will be using a Windows XP machine with a real serial port. This combo ALWAYS works. Some people can convince a Windows 7 machine to work, others can convince a USB/serial port adapter to work, but either of these last 2 are a roll of the dice.
Project25_MASTR
Monitoring
Texas
Not if it's a 32 bit version of Windows. 64 bit is what doesn't work correctly and gives the error, cannot communicate with device.
jaspence
Michigan
XTS 3000
I use the KAWAMall cable for both the XTS and EFJ5100 and have had no problems. Don't try to use the EFJ5100 on a Moto radio, as the pins are different on the radio connector end. Windows XP 32 bit with a true serial port is the best choice even if you have to buy an old laptop to get it.
ElroyJetson
Dell Latitude laptops like the D620, D630, D830, etc. are ideal for radio programming. They sold truckloads of them and they're cheap, plentiful, reliable, nearly bulletproof, and if they do have problems, spares are cheap and plentiful, too.
zz0468
I have had problems with the Kawamall ribless cables where it would work with, say, a desktop running XP, but not a laptop running XP.
It get's weirder. That Kawamall cable that doesn't work on a specific laptop to talk to an XTS3K would work on that same laptop running DOS and programming an HT1000. And a real Motorola cable and RIB would work fine with the laptop that won't talk to the radio with the Kawamall cable.
That same cable might work fine programming an XTS3K on yet a different laptop running XP or 7, or whatever. All of the above experienced on computers with real serial ports, running real XP (SP3), and real DOS.
I have personally experienced this weirdness, so I won't endorse that "ALWAYS works" statement. Clearly, your mileage may vary.
N4KVE
PALM BEACH, FLORIDA
Happened to me too. My Maxton ribless cable works on all my 3000's, & MTS 2000's except one radio with older FW. That particular radio requires a rib, & cable. Same laptop though.
pallen444
cable
Hello i use a USB to VGA cable works great i use windows 10 pro some times i have to update driver in device manager. when i first got cable had to look online for driver.
topdog1198
topdog1198
operating system
32, or 64 bit.
When I get home I'll check to see if it's 32 or 64. However I took your advice and purchase the deal computer running Windows XP hopefully this will eliminate the problem thanks for the help
Project25_MASTR
Monitoring
Texas
I have both 32 and 64 bit installs of windows 7 and the CPS works fine on both. Never had an issue.
I've never been able to get it to function on a 64 bit machine when it comes to serial communications.
ElroyJetson
Some system specs on my desktop running 64 bit Win 7:
Dell S5520 workstation motherboard, dual quad-core Xeon processor @3 GHz, 24 GB RAM, and some unknown but possibly genuine Intel brand RS232 serial card installed, running Windows 7 Ultimate Edition.
Project25_MASTR
Monitoring
Texas
Interesting. The only way I've been able to get it to run on my Latitude's is using Win XP mode to buffer it. Of course, the company won't pay to get me a computer with a hardware serial port...I can't even get a ruggedized laptop out of them (my last one fell off a D9) but was still usable for a while. Now they've got me in some new Win10 Latitude and I get errors left and right for things. Windows 10 is okay (it's got a lot of useless crap on it for a business machine) but I really feel like Dell has taken yet another step backwards on the build quality of their Lattitude's.
