XTS 3000r Programming Question
bosco836
Hi Everyone,
I have an XTS 3000R VHF (Flash Code 100001-000000-7)
As of right now, I have programmed in the Fleetnet channels for my region in Conventional mode (RX) (on an unused zone), in an attempt to listen to EMS. However, I get frequent bursts of "Machine gun fire"....which I can only assume to be the OPP operating in digital mode.
Having said that, is there any way to program these channels in to allow me to prevent the "machine gun firing" noise based upon the radio and Flashcode?
snoopyII
On the other side of the tracks
What exactly are you trying to listen to? "Fleetnet channels for my region" is kinda vauge. Maybe the agency/city/county/state, something of that nature would help.
davidgcet
that is because that is the factory default flashcode. basically the radio was ordered with no options.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (BlackBerry8350i/4.6.1.294 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/126)
He is trying to listen to Provincial EMS that uses Bell Fleetnet in Ontario, Canada
snoopyII
Based on only the info provided and the RR database (if still accurate), yes, you should be able to listen in on the digital TX, However, you cant control what you'll be hearing. If its a very busy system, you could end up hearing fragments of the conversation. Its a Type II SZ, so your radio as flashed wont and cant follow the trunking protocol properly. My best recomendation is pick the tower thats closest to you, program the CC's in a conventional personality, set your rx voice/signal type to 'astro' and your rx unmute to 'digital csq' and try it out.
