XTS 5000 Scan issue
Cashanova48
GMRS callsign WSAF780
Hi all,
Apon programing a XTS 5000 for scanning, I set up my scan lists, settings, and set the switch position A to scan. However, when I put the switch in A, I just a get fail tone and nothing happens. I couldn't find a whole lot of information out there for programing scanning, and it seems pretty self-explanatory, so I'm not too sure what could be causing this issue. Any help would be appreciated.
Cashanova
mbnv992
AZ
Sounds like you have nothing in your Scan List. So - A is setup to scan but the Scan List is blank / empty. Fill up your scan list and that’ll fix that issue.
Cashanova48
Thanks for the reply. This is my scan list that I have been trying to use.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Is that scan list assigned to the personality you are sitting on?
Came to say this.
OP:
Go to the personality for the channel you are sitting on, click on the scan tab at the top. In that tab, there will be a drop down to select the scan list you want assign to the personality. Select the scan list you want to use.
Keep in mind, the scan list can only have 15 members, plus the selected channel you are sitting on. In a zone of 16 channels, you can make a list of 15 to scan, and if you select the channel that is not on the list, it will be included when scanning.
So figure out which of your 16 channels(if it's a full 16 channel zone) you use the most and exclude it from the list, then scan while sitting on your excluded channel to scan all 16 channels in the zone.
In my XTS2500, I grouped my channels by location or function per zone.
This was so I could set up my scan lists to scan by zone. In each of my scan lists(one per zone), I have channel 2 to 16(15 members) from that zone, in the scan list. When I scan, I sit on channel one(it becomes the 'plus 1') in each zone so I can catch activity on it as well as the other 15 members in the scan list.
Cashanova48
Came to say this.
OP:
Ok, I have had that set up on the personalities, however, I figured out I have to be in zone 1 for it to scan, regardless of all of the scan channels being in zone 3. So when I hit nuisance delete, I can't go back to the channel to add it back, which is annoying but no game changer. I just have to turn the radio off and on again. Thanks for the help though.
Cashanova48
I also came across this vedio, and something like this would useful. I haven't been able to find out how they did this either:
KE4ZNR
Radio Geek
You are slowly learning why public safety radios usually don't make good scanners. Public safety users care very little about scanning. Their main concern is making sure they stay in contact on their main dispatch channel/talkgroup.
With that said you do have limited 15 channel/talkgroup scanning function in an XTS 5000.
You just don't have "bank" scanning like you do in a scanner. You have personalities that are slaved to zone/channels which are slaved to scan lists.
Think of it like a triangle: Personality->Zone/Channel->Scanlist.
All 3 have to reference each other to make a scanlist work. If you select channel 9 in Zone 1 then whichever personality is attached to that channel and whichever scanlist is tied to that personality and Zone/Channel is going to be scanned.
You just have to plan ahead and remember what you have referenced where.
Cashanova48
Gotcha, I really appreciate the help and feedback. I don't intend on doing much scaning (I primarily use the radio for GMRS repeaters and listening to ham P25 repeaters), but figured it would nice do use if the radio supports it.
KE4ZNR
Radio Geek
On the radio system I help maintain/manage: I have a ton of 700/800Mhz XTS 5000s from when we migrated to the APX line of radios several years ago. I can take one apart and put it back together in less than 5 mins. We still use some with our public works folks on our P25 system and they are still darn good radios regardless of band split when properly maintained and aligned.
Hopefully yours will last you a good while.
Cashanova48
Thanks, I'm sure it will. It's an older (2004) R variant, so hopefully it will go for a long while. That's pretty darn awsome and rare, Xts's still in service with an agency.
ryolsen8
BEE07
We still have a lot of XTS's in-service across the state with many smaller agencies.
KD8RFT
Grosse Ile Township, Michigan
This is from memory:
Create a channel in zones and channels specifically for your scan list. Zone 1 Channel 1 as an example. Call it County Scan
Have that channel (Zone 1 Channel 1) refer to a specific personality (personality 1)
In that specific personality have the scan list turned on and set to your scan list (scan list 1)
create the scan list 1 and add all of the channels (zone 1 Channel 2, channel 3, whatever you want) into the scan list.
when you tune to Zone 1 Channel 1, it will scan the channels you already set up in scan list 1.
Follow the triangle from above.
