XTS 5000R and FTDI USB to Serial DB-9 cable
N1XDS
ÆS Ø
Hey Guys & Ladies,
For the guys and ladies that has the cable..How do I install the FTDI USB to Serial DB-9 cable? I just plug the USB cable to the usb port and let it install the driver then hook the programming cable to my radio and then program my radio? Last few tries I am getting the communication error code so I am thinking its the cable. I am receiving a brand new cable tomorrow to see if that is the cause of the issue when trying to program my radio.
N1GTL
CT
Typically, you need to install the drivers BEFORE you plug the cable in. Run the driver installation from disc or download first. After it completes, plug the cable in.
N1XDS
ÆS Ø
Okay will do. Hopefully that fixes the issue "Communication error".
Project25_MASTR
TX-COMU
Texas
Unless you are using an OEM USB cable, you still need to select the Com port.
N4KVE
PALM BEACH, FLORIDA
Many people have problems using these serial/USB adaptors for programming radios. Some work, while others don’t. It boils down to what chip was used in the adaptor. The proper solution is to use a programming cable that plugs directly into the laptop. Even if this means buying a different programming cable. I purchased 2 different brand serial/USB adaptors with no luck. Purchasing the proper programming cable that did not need an adaptor meant instant success. Plenty of people on other radio forums have the same problem as you.
FFPM571
The Mid South
IOGEAR GUC232A and Motorola OEM Cable works every time.. install driver.. Open CPS find correct COM port ... no problem works on all 3 of my programming computers desktop CF29 and CF19
IOGEAR UC232A and Motorola OEM Cable works every time.. install driver.. Open CPS find correct COM port ... no problem works on all 3 of my programming computers desktop CF29 and CF19
I second this. It was recommended back in the day by motorola to use this before the legit oem usb cable came out.
Project25_MASTR
TX-COMU
Texas
They now have a new recommendation as he IOGear adapter does not play well with Pro CPS on 64 bit machines.
Very true. It is ideal for the 32 bit systems and xts series. In event anyone ever stumbles to this thread I woudlnt even attempt it on a apx. One may ask with common sense why would someone. You'd be surprised in time with third party cables.
zacabo
FL
I purchased one of the FTDI cables from eBay and the first one I purchased when connected just to the radio was making the radio go in to the encryption keyloading mode. I notified the seller and he immediately sent out a replacement. I have been using the OEM Motorola serial cable for my old XP laptop. Now with the adapter and cable I can program with my newer Windows computer.
Project25_MASTR
TX-COMU
Texas
The APX CPS doesn't recognize serial ports. Like TRBO, it identifies radios as IP networked devices. I don't believe there is a way around it, you have to use native USB cables on the APX radios.
N1XDS
ÆS Ø
Got the new cable and everything works like its should. :D
