XTS 5000R help
Medinaj68
I have an XTS 5000R and I have it programmed like all my other radios but for some reason I can only receive after I key up on my XTS 5000R. When I attempt to use one of my XTS 3000 or 2500 radios the 5000R won't receive while all my other radios work normally.
Any ideas how to resolve this?
62Truck
Ordinary Subscriber
Ø
Check your TPL, DPL settings, or your signalling settings.
XTS5000wellesleywv
Also go into personalities and make sure it is set to and
IMPRES2
If you are utilizing the scan function, then I recommend adjusting your search timer. Try turning your scan off or disabling it in the CP. Also check your unmute delay settings!
Best of luck!!
XTS5000wellesleywv
Yup you guys are right. At least I got the right menu tho[emoji23]
Medinaj68
Just wanted to touch base with all of you and thank you for your assistance I have since gotten the radio to work.
