XTS2500 "RADIO LOCKED"
K2NEC
NA
I have an XTS2500 M3 that displays "RADIO LOCKED" when powered on. I know this means the previous user had a password but if I force a good codeplug into the radio this should fix that right? Will I be able to read from the radio?
rescue161
KE4FHH
Hubert, NC
This is typical of the PRC153 radios. Marines will set password and then PCS or forget it and then the unit is stuck with a radio that they can't read or write or fix, so they end up sending it to Motorola for flat rate or sending it to DRMO for auction.
K2NEC
NA
I don't think it's a marines radio. Just some guy that forgot the password
Danny37
New York City
If the codeplug is not locked you should be able to read the radio and disable the radio power on password through the CPS. Or change it to your preference.
rbrtklamp2
Dupage County, Illinois
Actually I have done this in the past and it's actually a good way to UN-brick a radio. Not sure what you are talking about
I think what he means is not everyone knows how to do that and people who dont can brick their radio. Plus this is not a forum where discussing that kind of software is welcomed.
Sent from my SM-N960U using Tapatalk
K2NEC
NA
By "forcing a codeplug into the radio" I meant taking a codeplug from a different radio and uploading it to the radio I have to fix a brick. Not talking about Depot
K2NEC
NA
Problem resolved. I cloned the radio to one with no password and it works just fine. Thanks for the replies
