Xts3000 01/82
G472
Hello i am a corrections officer, My Radio Displayed this while Programming. Need Help ASAP I have work tomorrow
Anyone Have a Code Plug for a Model 2 UHF
RBMTS
Did you read and save the original code plug? If yes did you try to load that back in? Whatever changes you made apparently corrupted the modified code plug. Getting someone else's won't be much help to you as the firmware features of the radios may be different.
G472
Yes I have it saved, I Tried loading it back in and it still displays the error code. I really need this fixed. I really hope u can help
jtech48
OVB
I remember running into this a couple years back but on a XTS 5000. It took me clicking write to radio several times until it finally overwrote the old codeplug.
G472
Thank your for your response... It just keeps displaying Fail 01/82
This is the flash code
51000D-000400-0
NEED CODEPLUG ASAP
MODEL 2 UHF
Flashcode 51000D-000400-0
I_am_Alpha1
Sorry for the bad news, but you are totally buggered. As said, try reloading the codeplug again...but reboot the computer and make sure nothing else is running on it. After a few attempts it may inhibit your radio..as in kill. You may need depot to fix this...which may not be available. Big M may not be able to fix this since the radio is way past EOL. Retrying and depot are the only fixes I've been able to find.
zz0468
Read the codeplug from the radio, then without making ANY changes to it, immediately write it back to the radio. Do NOT just rewrite the RSS saved codeplug, that will NOT fix it. Read it, then rewrite it.
If that doesn't fix it, then there's nothing YOU can do that will.
The error is a checksum error in the codeplug. Reading the codeplug recalculates the checksum, and should fix it. If it doesn't, then it's likely a hardware failure.
G472
Xts 3000 Codeplug
Need Code plug for Xts 3000 Model 2
H09SDF9PW7BN
Flashcode - 51000D-000400-0 (H35)
ipfd320
W.Babylon N.Y. 11704
POST 1 {Quote}
Something Aint Rite Here--He Says He is a Corrections Officer--Why is He Screwing with a Possible PD Issued Radio with Programming???--Why and What is He Programming Into this Radio-----If This is His Own Radio Why is He Using it For Work???
He is Worried About Needing it For Work the Next Day???--Dont They Have Back-Up Radios????
It Came Up as an Error Code--Why Cant He Just Turn it into Motor Pool for a Replacement Unit
LIKE I Said Something Aint Right Here
POST 1 {Quote}
Believe it or not a lot of rural middle of nowhere small departments have personnel that alter the scan lists or add channels as its a act of Congress to get it done.
While it may seem odd I could name well over 20 sheriffs offices where portables are done in house by deputies but in those cases it's known by the sheriff himself and the mobiles are us ally installed elsewhere when a new unit is bought and as time goes a deputy or others familiar with it change the conventional programming in them locally.
I've seen some jails or small sheriffs offices in small rural counties tell their employee change the scan list I don't care. Thlaw typically don't have a shop to go to or if they did the shop closed, nobody will approve a new contract.
I've also seen the I'll change it myself without approval end youre speaking of when those ones do have a system admin and or shop they go to.
Being a 3000 in a DC sounds to me it's one of the rural type entities where it's mix and match and some update themself with lists they get inside. Though I'm just guessing here.
Happens more than you think in rural places where there is no shop, admin or if there is its a pc IT with no knowledge of radio communications. They'll contract out repeater repair and console repair on a special basis if needed pay the bill and that's it. It's happening more than a lot think out there.
What this case is who knows. The answer was given though. Only thing you could do is keep trying to read it then write back to it. I've seen it go either way with these it working eventually or not at all.
Some small rural entities still have old Jedi series out there or ht1250 waris series in use, or older. Some will ask can in get a new radio and program it myself and are told ok in the small rural places in the USA.
gatekeep
FAIL 01/93
New York, NY
Not to derail this thread at all; but his flashcode is suspicous for an XTS3000. 51000D-000400-0 seems to have conflicting system types. It implies he has options H35, H37 and H38. Because it has the Q173 option, I would assume it would only need H38. H35 is implied, when H37 or H38 is present.
Odd is all.
zz0468
He's been given the accepted fix for the problem he's reporting, but for whatever reason cannot or will not confirm that he has actually taken the exact proper steps. Perhaps he should just be left to his own devices...
KevinC
32D2T/957.282
I'm everywhere Focker!
In my experience this usually means either they aren't getting the answer they want or they aren't telling the whole story.
