XTS3000 mic adapter
ttiiggy
Motorola BDN6676
BDN6676D - 3.5mm Jack Adapter Quick Disconnect Latch - Motorola Solutions USA
That is the 3.5mm jack version. I see some 2-pin version ones around.
Does a Motorola XTX3000 or XTS5000 still work normal if I leave this attached onto the radio and don't have another device plugged in?
Can I have NO headset plugged in and still use the radio normally without taking this off?
Can I use the PTT button on this and talk into the radio mic without a headset plugged in?
Kenwood didn't fare well for me:
http://forums.radioreference.com/kenwood-forum/177953-2-pin-plug-adapter-kenwood-tk-5210-a.html
How does Motorola work?
FFPM571
The Mid South
Yes
Yes
No
Unless the mic/ ear phone is plugged in it. The radio will work like normal. Once the mic/ speaker is plugged in then it will work as designed. The PTT only works with the headset is in place
KG4INW
Midlothian, VA
You'll also need threaded 3.5 mm devices (earpieces, etc) to work properly.
ttiiggy
Gezelle007
Lurker in the Deep
Oregon
You could upgrade to a Hirose style headset. While a lot more expensive than the 2 pin or 3.5mm style, the connection is very secure. Like the other adapters, it will allow your radio to function normally if the headset isn't connected.
