XTS3k programming on windows 10?
I've researched and seen plenty of sources on here say it is possible but equal amount saying it won't work right. Haven't bought one yet but I want to try and see if my cable and software will work. I also did the "run as 'older system'" if that works. Thanks.
marcotor
I ♥ÆS Ø
Sunny SoCal
Because AstroSaber/XTS3000 CPS was developed 30 years ago to perform on a 32-bit Windows platform. It's a lot more than "changing the bits", and probably way over your head if you think it was a "bit change". The differences between x32 and x64 are too numerous to ennumerate in this forum. x64 addresses terrabytes of memory, multitasks efficiently, is multi-core capable, much faster, much more efficient moving bits from here to there.
Just use x32 Win10 or Win7 for that relic.
