XTS5000 Encryption Keyloading
zacabo
FL
I have an XTS5000 that when I attach the KVL 3000+ cable (OEM) to the radio it will not enter the keyloading mode. I have tried to switch the housing with a working one and it didn't work. The contacts on the radio seem fine and I can read and write to the radio. I ended up having to switch the encryption module with one already programmed. Has anyone come across this before? Any fix?
duffy109
Greater Cleveland Ohio
My first thought is did you verify that the encryption is a feature in that specific radio? Once you used the already programmed radio, did it work?
zacabo
FL
Yes. the radios have the same encryption algo's and same flash. I was playing with the cable and it appears that the cable wasn't making good contact to the radio. I was able to test before my KVL battery died.
rbrtklamp2
Dupage County, Illinois
Also make sure that your secure setting are set to hardware encryption. If the radio has ADP selected under the secure tab it will not allow you to load keys properly.
Sent from my SM-N910V using Tapatalk
zacabo
FL
That's a great point that I didn't think of. I wiped the radios because I'm doing testing with tactical OTAR. I forgot about setting it back to hardware.
