Hello
sorry to jump in on the thread but figured I'd ask a question since I am having similar issues.
I have two Xts 5k's 700/800 MHz models that I have setup for NAS using the hidden TG method.
I went through all the correct instructions of changing the transmit offsets in case it tried to transmit and so on.
On the one Xts 5000 it has firmware version 12 and operates great by picking up all communications and so forth. It does appear to not affiliate with the system because the red light does not flash at all and all the NAS safety measures were followed.
On the other Xts 5000 it had firmware version 15 and had an exact clone of the code plug on it from the other xts 5k the operates correctly. Every time I went to connect the antenna the red light would start flashing indicating it was trying to affiliate with the system. After trying everything with that radio I figured it might have been a bad radio. So, I was able to exchange it for a new one through the seller that I bought it from. This one also came with firmware version 15 on it and right off the bat it was having the same issues the other one was having with it appearing to attempt to affiliate with the system. So, I was stumped but thought maybe it was the firmware, so I (legally) updated the firmware to version 20, because I was unable to locate a copy of the version 12 firmware like my other xts 5k has. I re cloned the code plug from the other radio and once again even after the firmware update it appeared to try to affiliate with the system because the red light started to flash. After this I decided to try to disable TX by setting the eccentric switch to TX disable. This appears to have stopped it from trying to affiliate with the system, but now I miss a lot of the conversations compared to the other NAS xts 5k running firmware version 12 and my XTS 5k that I am issued through my agency, that is affilated with the system and that I use at work on a daily basis.
Any idea what would cause this and how I can correctly fix the issue while making sure that it is still on NAS. As stated before I am issued a xts 5k through the agency that I work for, with that being said I understand how important it is for unauthorized people to not affiliate their radios with the system, because the last thing I would want is myself or one of my coworkers trying to call for backup or get a hold of dispatch, and them not being heard because someone decided to affiliate their radio onto the system.
