XTL/XTS5000 XTS5000 Priority channel scan issues
Los Angeles County / Marin County, CA
I have a XTS5000 and noticed that when I turn on Priority scan for the selected channel that the audio clips on channels that aren't the one selected. I assume that this has to do with the "time between priority samples" setting in the programming software. Is there any way to make it so I won't hear the break in audio while still having a reliable priority scan on?
Also, what is "priority channel marking"?
Any help would be appreciated, thanks.
GTR8000
NY/NJ Database Guy
BEE00
Nope, not possible. It's always going to cut out briefly while sampling the priority channels in a conventional scan list.
The description of Priority Channel Marking is in the ASTRO 25 CPS help file.
GTR8000
NY/NJ Database Guy
BEE00
I have mine set for 550ms. Call me crazy, but I find that the shorter the sampling interval, the easier it is to understand the audio on the non-priority channels. 550ms may actually be the default, now that I think about it. Then again, I don't scan much conventional these days, and this isn't an issue with trunking, so there's that.
500 ms is the default. I'll see how I like it with 550.
GTR8000
NY/NJ Database Guy
BEE00
You're not going to notice a 50ms difference.
GTR8000
NY/NJ Database Guy
BEE00
You can't. Scan lists are not selectable like that. A scan list is selected in a conventional or trunked personality, and any channel within that personality uses that scan list. If you need multiple scan lists, you will need to create additional personalities and assign those other scan lists to those personalities, then create new channels in the zones which are tied to the other personalities.
